Map sensor?
Old 02-02-2012, 04:42 PM
j250hd's Avatar
j250hd
j250hd is offline
Map sensor?
My CEL is on took it to ford and they said I need a new map sensor. My question is, I've been driving it for a little bit cause it seems to run fine, mpg is still around 15, is it bad to drive like this or should I not be too worried about it?
Old 02-02-2012, 04:59 PM
fordpride's Avatar
fordpride
fordpride is offline
It's not gonna hurt it
fordpride's Avatar
fordpride
Dud they give you the code?
Old 02-02-2012, 05:28 PM
j250hd's Avatar
j250hd
j250hd is offline
No code. Forgot to ask. Had it at another diesel shop and they couldn't even get their scanner to sync up.
Old 02-02-2012, 05:50 PM
427 fordman's Avatar
427 fordman
427 fordman is online now
Unplug the electrical connection to the map and drive it and see if it runs better. That usually tells you if you have a bad sensor. It will cel, but if it runs better, the map is bad.
air1jpg
2004 - 2008 F150
02-19-2014 09:22 PM
aphotic26
6.4L Power Stroke Diesel
18
08-30-2013 05:15 PM
ballbandit
Escape & Escape Hybrid
07-11-2009 10:32 PM
dmanier
1978 - 1996 Big Bronco
10-27-2002 04:46 PM
Quick Reply: Map sensor?
