EOT
Old Jan 31, 2012 | 09:36 PM
bearhugger's Avatar
bearhugger
EOT
If the eot sensor is bad,what are the symptons and how will it effect the running.
Jim
Old Feb 1, 2012 | 06:36 AM
DIYMechanic's Avatar
DIYMechanic
If the EOT is bad, you may see the EBPV closing when it shouldn't (assuming it is plugged in and in working order), I would thing you may also see very low boost numbers as the PCM won't fully adjust the ICP until it sees the EOT up to operating temperatures. If you have access to AE or a scangauge it will read the EOT and then there will be no doubt.
Old Feb 1, 2012 | 07:23 AM
fordpride's Avatar
fordpride
If you don't have a scan tool then you can ohm the sensor to see if it off
K Ohms__Volts____TempF___Temp C
826______4.75______-32______-36
785______4.75______-30______-34
575______4.73______-22______-30
525______4.72______-20______-29
365______4.68______-10______-23
300______4.65______-4_______-20
250______4.63______0________-18
192______4.6_______10_______-12
173______4.55______14_______-10
139______4.49______20_______-7
103______4.4_______30_______-1
98_______4.38______32_______0
64_______4.18______40_______4
59_______4.13______50_______10
43_______3.92______60_______16
37.3_____3.8_______68_______20
33.6_____3.73______70_______21
26.8_____3.53______80_______27
24.3_____3.44______86_______30
21.5_____3.32______90_______32
17.2_____3.08______100______38
16.1_____3.01______104______40
13.9_____2.84______110______43
11.2_____2.59______120______49
10.9_____2.56______122______50
9.34_____2.38______130______54
7.55_____2.11______140______60
6.28_____1.89______150______66
5.34_____1.72______158______70
5.32_____1.71______160______71
4.48_____1.52______170______77
3.84_____1.37______176______80
3.75_____1.35______180______82
3.17_____1.18______190______88
2.8______1.09______194______90
2.68_____1.04______200______93
2.2______0.88______210______99
2.08_____0.86______212______100
1.87_____0.78______220______104
1.56_____0.67______230______110
1.33_____0.59______240______116
1.19_____0.53______248______120
0.38_____0.17______CEL Below This
Old Feb 1, 2012 | 08:15 AM
DIYMechanic
Very good info Mike, I'd give you some reps, but the warden says no go...
Old Feb 1, 2012 | 08:21 AM
fordpride's Avatar
fordpride
It's al good I haven't been able to rep anyone for two weeks
Old Feb 1, 2012 | 10:13 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
X2 and X2 oh that.
Old Feb 1, 2012 | 10:51 AM
bearhugger's Avatar
bearhugger
Thanks guys for the info.
Jim
Old Feb 1, 2012 | 11:42 PM
oldbird1965's Avatar
oldbird1965
I got him, probably back in jail now!
Chip Conklin
Feb 7, 2019 06:47 AM
brichert
May 26, 2017 06:46 AM
Capt.Schenk
23
Jan 19, 2017 08:19 AM
teamroper98
Jun 1, 2006 09:07 PM
444dieselrod
Feb 20, 2005 07:15 PM
