bracket suggestions
Old Jan 31, 2012 | 11:01 AM
jerryst's Avatar
jerryst
bracket suggestions
Well i have my rotors, calipers and i found the right hoses for my disc brake swap on my 55 f100. Now I need suggestions for the bracket to mount my master cylinder and booster. I want to mount this in the stock location. I have a floor mounted 3 speed. I also have questions about adjustable proportioning valves. Any recommendations would be appreciated.
Jerry
Old Jan 31, 2012 | 11:45 AM
sdetweil's Avatar
sdetweil
MidFifty (and others) sells a bolt on bracket for booster based masters under the floor.
(I am using one for my setup)..
what questions on the prop valves?
Sam
Old Jan 31, 2012 | 11:58 AM
AXracer's Avatar
AXracer
I have an underfloor bracket and manual dual circuit disk/drum MC I'm not using.
I'd recommend buying a proportioning valve matched to you brake combination, and trying it. Then you can put a simple inline adjustable valve into whichever line you feel needs reducing if needed.
Old Jan 31, 2012 | 03:44 PM
jerryst's Avatar
jerryst
my question was do I need to put in a adjustable proportioning valve along with the valve you can purchase from mid fiftys for front disc rear drums. And Axracer will the bracket you have support a power booster bolted on? and can I use this with my three speed?
Jerry
66low
Feb 20, 2015 11:28 AM
Ddg0919
16
Sep 29, 2014 07:33 PM
dwil
Jul 30, 2014 02:12 PM
Wyatt66f100
17
Dec 13, 2007 11:15 AM
PASTORMATTHEW
Oct 12, 2006 05:42 PM
