hey new guy here
I think I have most of the parts I need to make a horn work on my truck but don't know what else I'm missing. I would love any help with this. I think i need two brushes, does dennis carpenter sell both that I need? What does the shiny horn washer do in the last picture? Does it look like the parts are in the proper place?
UH OH! How do I download pics? there isn't an option.
thanks in advance
jeff
Please, when asking questions, list all the pertinent info. 1967/70's have a horn ring or button, horn insulator and brush.
1971/72's have a vinyl horn pad that contains the horn switch, no horn brush/insulator.
Your profile says: 1967 F250. On the outside of the steering wheel, below the horn ring or button, hand pressed into the wheel is the horn brush and insulator (C2OZ-13A821-A).
The brush has a thin copper wire that snaps in two.
And, peeps are unaware, remove the wheel, then tilt it, the horn brush falls out. Then when they re-assembled, the horn no longer blows and they wonder why.
Carpenter in Concord NC (800-476-9653) has C2OZ-13A821-A .. Horn Brush & Insulator Kit / Obsolete from Ford, but...there are several sources that have it NOS, here in CA.
What city do you live in? I'll list the closest sources.
Applications: 1961/66 F100/250 2WD & 1966 F100 4WD (use w/3 spoke steering wheel) / 1967/70 F100/250 / 1969/70 F350 // 1962/64 Fairlane / 1963/64 Galaxie / 1964/66 Thunderbird / 1965 Mustang w/a generator.
thanks in advance
jeff
One end of the brush has a cone shaped end...thin copper wire fits into it, has a ballpoint pen sized spring over the wire, then a flat contact plate at the end of the wire.
The thin copper wire snaps, so what remains of the brush can work its way past the horn ring/button, goes bye bye.
Where do you live in CA?
Originally Posted by 76f350spercamprspeal
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
Quote:
Originally Posted by old_dan
You can also go to the "Garage" tab and start an album right here on FTE. After you post pictures to an album, we can look in your album, but you'll also be able to "insert a picture" by pasting in a link to the picture in your album.
It seems awkward, but whenever you "insert a picture" to one of these threads, the forum is looking for the picture somewhere on the web (which is always available) rather than from somewhere on your hard drive (which isn't always available).
The thin copper wire snaps, so part of the brush can work its way past the horn ring/button, goes bye bye.
Call Bo @ Mustang Service Center in NoHo (818-765-9266), he prolly has the parts in stock. Take Laurel, Benedict or Coldwater Canyon or Beverly Glen to 11610 Vanowen St.
The spring that fits between the horn button and the wheel is different with the horn ring.
I think my horn can be working soon, just one more question. There are two brushes to make the horn work, are they both the same size and shape?
jeff
