XRF Ball joints
XRF Ball joints
Hi all!
I'm having a little bit of a issue trying to figure out what set of XRF ball joints to order for my truck. It is an Extended cab 96 F-250 4x4 with a Dana 50, and 3850 lbs axle.
it looks like The tire club company that had them are now selling them on ebay. The ones that I see are either for 4600 lbs axle, Dana 60, or 99-newer truck. I'm just trying to make sure I order the right ones, because I'd hate to dig into the tearing the axles down to figure out I ordered the wrong ones.
I did reach out to the seller and let them know what I had, and they sent me a link for ball joints for a 4x4 f-150. https://www.ebay.com/itm/184709081054?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=4sqnCAS2St-&sssrc=4429486&ssuid=qcovN6Y2TI6&var=&widget_ver=a rtemis&media=COPY
I just want to make sure these are the right ones for my truck. Any help would be appreciated!
Are you sure it’s a 3850# axle? D50 TTB’s are 4,600#. Can you post up a picture of it, and one of the hubs. It should embossed on the bottom of the differential. (Ie. “50”). It should also be on the VIN decal inside the driver door jamb.
Possible it has been swapped out at some point, I’d look at the axle it self to confirm. Post up pics.
Yeah, ok. I thought all D50 were 4,600#. Maybe not.. maybe some used a different knuckle. Do you know the history of the truck, modified or swapped out? I’d be curious what a dealer says.
I forgot about this thread…. Have a read through.
https://www.ford-trucks.com/forums/1...-problems.html
Just for kicks post up a pic of the hub, and take a look on the bottom of the differential.. Im curious what is embossed on it.
Edit. both build dates are the same month and year.
Yeah.. I don’t know to be honest. I only know of the Dana 50 TTB 4,600# axle. Not familiar with this at all, and I can’t find anything online that confirms a 3,850# Dana 50 TTB. Hopefully someone else can chime in on it.
Looks like a 50 hub and locking hub to me, you’d have to pop the cover off to confirm.
Other than what is in the other thread, it’s possible someone swapped in a D50, whole or modified. Other threads I remember saying extended / crew cab 250’s only came with a D50 - I don’t know if that is correct or not. I’d also want to check the axle shafts to see what they are, comparing the yoke (u joint) size (should be a 1350) to confirm they are D50. Lots of guys have modified these trucks over the years, hence why I was asking if you know the history of the truck.
Here’s a couple links. Lots of info, and lots more threads if you Google Dana 50 TTB…
https://www.ford-trucks.com/forums/1...tb-thread.html
https://www.blueovaltrucks.com/tech-...tb-front-axle/
If it were me, I’d either disassemble, measure and then order.. a pain I know, and maybe not an option to order XRF if down time is an issue. Or take a chance they will work and order up a set.
Or, call Dana Spicer tech line and run this past them, as well as your local dealer. Post up what you find out.
The ball joints are Items 37 and 40, referred to as Socket - Upper and Socket - Lower respectively.
See attached BOM file.
The following users liked this post:
This is great info, I'm just glad I'm not the only one stumped with the 3850 axle label.
I bought this truck about 5 years ago, prev person said the truck was used in Forestry, not much more info was given.
I think it will be best to just a break it down and see what I have and go from there. I see Moog joints for both axle weights, but I didn't have good experience with Moog on another vehicle.
I'll report back once I do.
Yeah, I’ve had bad luck over the past several yrs with Moog ball joints.. I have one to change out right now that has maybe 10k miles on it, it’s clunking around already..
I used XRF (the whole front end kit) on my 96, everything fit and works well. Don’t have enough miles on it to comment any further, but I’ve yet to read a bad review on them.
Good luck with it, come back and let us know what you find.
edit. Just a thought, but if it was govt truck, maybe a custom fleet order of some type? Who knows..
Hyakkimaru
04-30-2022 02:41 PM
cochran07
01-01-2010 04:13 PM
