Does anyone know Van turbo will fit 2000 F350
you will also need a exhaust outlet adapter.
riffraff sells them
http://www.riffraffdiesel.com/mm5/me...31-TRB-TOUTLET
riffraff sells them
It being worth it is an understatement................... Wait till you hit the skinny pedal on the right the first time!!!!!!!!
might as well get the rebuild kit and nock that out when you receive it. Ity cost less than $100 and comes with all new O-rings for the pedestal as well.
Here is the link to the procedure - not difficult at all.
Welcome to BDrummonds Van Turbo Rebuild Web Page
I end found better deal and less miles.
It came out 2002 F250 with ONLY 88K miles for $165 plus shipping.
He ever show me alot GREAT PICTURES I could see compression wheel it far better condition. Less rust too.
I thought about try van turbo but cost to convert seem to alot $$ for unemployed worker so it cheaper to go with factory.
I hoping it fix turbo surge/fluctuation that I still see at 15 psi or above now.
My turbo on it had 222K miles and Previous owner ran with Fram air filter plus broke air filter housing it doesn't seal so I am sure it been dusted.
"Dan do you really want Fu#k UP that $1500 turbo because you were too cheap to had shop do balance or install W.W or Rebuilt for you" It will throw balance out and CHEW shaft/housing.
1 friend say you be STUPID to put any aftermarket parts on TURBO. He say turbo from factory were FINE. I try to say I disagree but didn't want start argue.
Before that I never thought turbo were that serious if one mistake could RUIN engine and break down far away from home.
you'll get mixed opinions on the "balancing" debate. I installed a w.w. for the surge problem, with no balancing. Going on 5-6k miles now. As of recently, just towed 250+ miles, with headwind, hills, nothing under 2300rpm, so, turbo was zinging, and didn't miss a beat.
Reason for install of wheel, towing same hills/miles, and couldnt push over 10psi without it pulsating...surging.
in our Excursion - I bought the rebuild kit from Riff Raff Diesel & the Wicked Wheel for the stock turbo with 195K on it. Installed it (no balancing) and have @ 5,000 miles on it, no problems.
In our F-250 installed the Van turbo with wicked wheel over 5 years ago and @ 100,000 miles on it with lots of towing. No balancing and no problems.
MONAVIERONJON
12-10-2014 09:26 PM
rat49f6
05-31-2010 07:23 PM
farmb0y
07-27-2009 09:41 PM
