Got a NP435 for a swap
  #31
Old 02-12-2012, 11:12 PM
fordman75's Avatar
fordman75
fordman75 is offline
Yes the shift fork pads should come in any good master rebuild kit.
  #32
Old 02-14-2012, 07:51 PM
ManfredVonRichtofen's Avatar
ManfredVonRichtofen
ManfredVonRichtofen is offline
I see the kit from Novak with Syncro rings is like $350! :-o
The master rebuild kit from JBY is like $169 but I don't think all parts are in it..
  #33
Old 02-14-2012, 08:05 PM
Rusty_Old_F250's Avatar
Rusty_Old_F250
Rusty_Old_F250 is offline
I bought my fork inserts from bronco graveyard, but I just checked and they aren't listed anymore, strange! This place has them: Manual Transmissions by Unit Code: NP435: Manual Transmission Parts - Online
My reverse gear looked like that too, still works ok though.
Sam
  #34
Old 02-17-2012, 06:32 PM
ManfredVonRichtofen
NP 435 Deluxe Rebuild Kit - WILD HORSES Early Ford Bronco Parts
N.P. 435 Master Rebuild Kit
Which is better? What else would I need in either one of these kits?
Trying to find a low/reverse gear.
  #35
Old 02-17-2012, 09:00 PM
fordman75's Avatar
fordman75
Neither of those are the complete rebuild kits. You want a kit that includes all the synchro parts. Like one of these. I just don't about the bearing quality in this kit. I don't know who makes the bearings that are in this kit.
Ford NP435 435 Transmission Deluxe Rebuild Kit 64-87 | eBay
You can find the gear and other parts here: New Process 435 Manual transmission parts, rebuild kits & parts . - Drivetrain.com
  #36
Old 02-18-2012, 12:24 PM
ManfredVonRichtofen
Maybe that gear will be ok with how it is?
  #37
Old 02-18-2012, 12:57 PM
fordman75's Avatar
fordman75
You've got the transmission out, now is the time to fix it! Having to tear the truck back apart because you tried to save $80.00 just sounds like a bad idea to me. But it's your truck do what you want.
  #38
Old 02-20-2012, 05:48 PM
ManfredVonRichtofen
Well I guess I can put it in. Hell, might as well fix it right the first time then go back later.
It's called the Low/Reverse gear?
If gas gets up to $4+/gallon...it probably will be sitting some more than driving.
  #39
Old 02-20-2012, 06:40 PM
fordman75's Avatar
fordman75
Yep that's it.
  #40
Old 06-26-2012, 12:22 PM
drivetrainamerica's Avatar
drivetrainamerica
drivetrainamerica is offline
Originally Posted by Blackfoot Big Block
There are quite a number of companies that offer rebuild kits.
Last fall I went down this road with a Borg Warner T-18.
I see Novak recommended, when I called them I had a few questions and they never called back.
One company I would avoid is Drivetrain America. I called them and asked specifically if there were any Chinese made parts. I was told some of the gaskets perhaps but none of the bearings would be. After receiving the kit sure enough the first bearing I looked at was made in China. It literally took weeks to get the refund.
Bronco Graveyard also has transmission rebuild kits. I would verify on the phone what the status of their current supplier is. Though their website may say one thing, the reality is they may be using a new supplier and the website may be incorrect.
dear blackfoot big block-
im very sorry to hear that you had an issue with our business Drivertrain America, i am the owner , and i would like to personally apologize for any problems that you had with us , i pride myself on putting customers first and servicing them , normally all of our Timken Dt components kits do include american made bearings , like timken, koyo , ntn , skf , sometimes our suppliers may have to substitute a bearing if the standard bearings in the kits are on backorder , please accept my personal apology for any problem or inconveinence this caused , as a family owned business my goal is total customer satisfaction in every way , if there is something i can ever do to make it right please let me know and i will absolutely make it right with you , thank you for your business
bjmayberry2
17
09-22-2016 10:40 PM
alpha/omega
Offroad & 4x4
295
05-15-2014 09:36 PM
ChuckRob
17
03-11-2014 06:02 AM
1967 Turbo 6.9
01-29-2013 07:38 AM
my85fordIDI
306
07-21-2012 09:14 PM
Quick Reply: Got a NP435 for a swap
