99 7.3 lost power won't start
Hi Everybody. I have a 99 F450 with a 7.3. It has a superchip set at tow safe. I was driving down the interstate yesterday and all of a sudden starting loosing power and the truck had a hard time staying at 55mph. I pulled over cut the engine off to it check out and would not restart. So i towed it home.
It turnes over fine but no smoke.
Checked fuses all looked good.
SES lights and dash lites come on like normal.
HPOP oil level within 1" of top.
Fuel in fuel filter. Filter looks good.
I am going to change oil and filter it is due for that now.
I hooked up AE sftware to it and got these codes:
P0470
P1209
P1211
P1212
P1280
P1282
With ICP plugged in got these reading:
ICP pressure: 83
ICP Duty: 98
RPM: 140
Volts: 9.5 Had charger hooked up
With ICP unplugged
ICP pressure: 2307
ICP Duty: 32
RPM: 140
Volts: 9.5 Had charger hooked up.
I cleared codes and tried to start it got one code: P1280
P0470
P1209
P1211
P1212
P1280
P1282
ICP pressure: 83
ICP Duty: 98
RPM: 140
With ICP unplugged
ICP pressure: 2307
ICP Duty: 32
RPM: 140
Buzz test was good.
ICP had some residue of oil in it but was not bad. Other than oils in it can it be checked out or just replace it?
IPR should I take it apart to check o rings and see if it is sticking?
Sounds like you are not building pressure. That could be from the IPR bypassing all the oil back from being stuck open. Have you checked the wire harness on the drivers side valve cover for chafing? The wires to the 42 pin connector can rub through causing issues. A stuck IPR or a bad sire make the most since from what you have posted.
The ICP did need to be replaced based on oil in the connector.
Replaced batteries one was no good. Engine turns over alot better and has 11V when turning over. Did not start engine though.
Replaced ICP and IPR truck started up and is running great.
I just hate when people ask for help on here and fix their truck but dont come back and undate their thread and let everybody know what the out come was to fixing their truck.
CFAutoTransport
06-04-2018 04:06 PM
cbuttre835
04-08-2018 08:43 AM
fishman002
11-06-2013 01:04 AM
