Why is the #8 plug always the most fouled
Really, no one knows this one? It is because of the firing order and the physical location of #8. At the back of the motor and #8 fires right after #7 and for some reason to do with the design, it makes #8 foul more. Don't be pulling the motor to check the drains, that's bull. Do a compression test and replace the valve seals but if the valve guides are worn, the seal won't help.
How do you think 8 firing right after 7 has ANYTHING to do with plug fouling? I think this info was pulled directly out of the bears a s s.
on
Huh??? I fixed an old GF's '79 RallySport Camaro the same way- she had bought it new and never changed the oil (this was in '86) Valve covers were almost full of oil (more like tar at that point) when I pulled them off, and was smoking like a stove and killing the back two plugs on both sides in a day, as that little Chebbie doesn't have the gaps in the intake like an FE, and the drainbacks were completely clogged
Congrats on being another person who was able to check and clean the drains without pulling the engine- that was the best one I've heard in a long time
Sounds like she's just a little tired, and you're getting a little blowby out the breathers- but your typical FE will usually still do a lot of chuggin' when it's a little tired
I think my 390 in my 74 is suffering from this very same issue. It smokes out of the drivers pipe (true duals) when idling. I pulled the valve cover and found chunks of black "stuff" all in the heads, and the oil drain back ports. Cleaned em up, and it still smokes a bit...but not like it was before.
Gonna run a few oil changes through it, buy a master gasket set and pull it apart. She's a leaker, and I can't stand one.
Violeta
07-05-2009 02:47 PM
adipose
16
05-05-2008 11:08 AM
