Tranny slips tuned not stock, what's up with that?
I'll try and keep this as brief as i can. 04' 6.0 with 34k on it. Has been tuned since about 20k first with Spartan tune and then with Innovative. Nothing crazy tune wise and shifting at 4k. I only have the problem when there is a tune in it and when the outside temperature is below 50. If i let the truck warm up for about 5 to 7 min i have no problems. If the truck is cold or doesn't warm up it will surge and slip when i pull away from the curb. I'll slowly pull away and the rpm's will rev up, with no added pedal input, and the tranny feels like it is slipping. If i put the truck back to stock program i have no issues what so ever. I never had this issue with Spartan's aggressive street and only noticed it with the more aggressive tunes. The filters and fluids were changed at 30k with minimial metal in the pan around the magnet.
Any help would be appreciated. I drive this truck on weekends and have never towed with it or used it as a "truck".
I did contact Innovative end of last year and they could not find info on the tune they sent me so i didn't push the issue and just made sure to let the truck warm up. However i've needed to have the turbo cleaned twice before because of letting the truck idle for periods of time when it was cold. So now that it's out of warranty i try to avoid any idling that's not 100% necessary.
And when i let it warm up about 5 to 7 min, when programmed, and then hammer it no slip what so ever? That's what i'm trying to figure out. Could we be talking about a solenoid issue? No codes are being thrown. And again it's only got 34k on it. While i understand that a program could destroy a trans on day one, i have no issues with stock program and issues with more than one programmer's program.
I appreciate your reply but why can i hammer it stock and no slip what so ever even cold with no warm up.
The bad tune(r) could have done damage that's beyond a solenoid.
My BEST advice I can and will give you about this, de tune the truck, bring it to ford and have them scan the transmission, have them go over it and see if they can find and signs of failure, slipping, or solenoids not working properly.
If it comes back good, leave it stock unless you can afford to replace the transmission. It cost me about $3,600 to have a reman installed in my 2006.
Obviously something is wrong though, a transmission shouldn't slip(at least one with less then 35k miles)
When tuned, i used to remote start truck from my house and walk out the 50' to the street after the truck starts. Get in and pull away from the curb. Now if i don't let it idle first for the 5 to 7 min i have to idle down the street and not accelerate or the rpm's will rev up, without any added acceleration by me, and the tranny will seem to slip as it shifts.
Now if it's stock and i do exactly the same thing from the point of remote start, i can get in my truck cold, and accelerate to 30 mph letting the truck shift one or two gears no problem.
I live in a residential area and stay around the speed limit so when i say "hammer" i mean accelerate continuously until i hit about 30, sorry for the poor choice of words
I would agree if i put the pedal to the floor cold and my trans is shot i deserve that.
