no throttle respose
Thats how we roll here ...
Hi there, I was messing with my throttle pedal assembly down there once to adjust a fast idle solenoid cable for the pulling unit on the service rig and ended up with the same problem. It's true that if you dont fully seat the switch at the idle position, it will not rev when you start to roll the pedal into that cam roller. He's right , you should hear a click as soon as you depress the pedal, meaning your coming off of the idle v.s. and fixing to call for some fuel. If the pedal arm or the 90 deg. bend thats there for the switch is just a hair off = no go. It all has to happen like in a credit card width or so. Check it out and good luck, Jay
IVS & TPS source - NEW
This is the Manufacturer and P/N for the Ford IVS. It is the actual part made for Ford.
I had purchased all the existed stock before and was told that's it. Now it appears that they have run another batch. They currently have 70 pieces in stock. I would recommend getting one as a spare.
Look here:
Onlinecomponents.com | Franchised Distributor of Electronic Components
You may have to search the P/N, but it is there.
Cutler Hammer/Eaton SS22BW32-330Y
TPS - Dorman
Dorman makes the aftermarket TPS. I'm sure it is a good part.
Dorman Products - Search Results
Dorman 699-200
There you have it!
~DR
__________________
Look here:
TPS - Dorman
Dorman 699-200
There you have it!
~DR
__________________
its possable they gave you the wrong tps, thats what happened with mine, i replaced mine it didnt work, it looked just a little different on the inside where it controles how much throttle you give it. so i went back they wouldnt return it, made me mad so i wet to the junk yard and i got one from there and the junk yard oe worked just fine.
