Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Lightning oil cooler
Old 01-30-2012, 02:56 AM
Goob's Avatar
Goob
Goob is offline
MY question is on a 1993 351 Windsor lightning motor can I turn the way the oil cooler sits around ? it bolts on the oil filter outlet and has two ports for the water to run through but it won't fit rite unless I turn it all facing the back of the motor. I don't think this will cause a problem but just wanna be sure thanks for any help!!!!
Old 01-30-2012, 08:57 PM
Blurry94's Avatar
Blurry94
Blurry94 is offline
As long as you extend the coolant lines then it shouldn't be an issue. Otherwise, you can remove the oil cooler, install a one piece lower radiator hose from an earlier F-series (like a 1990) and run an FL-1A oil filter instead of the FL-820s.
3speed
19
11-21-2019 09:49 PM
murphf-150
08-03-2010 07:55 PM
chopper_53e
03-22-2007 07:50 PM
qikbbstang
02-03-2004 12:28 AM
Sportdeck262
03-06-2003 12:15 AM
Quick Reply: Lightning oil cooler
