Does anyone see huge improvements in premium vs reg. unleaded? - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
Reload this Page >
Old 01-26-2012, 04:59 PM
F-250 WARHORSE's Avatar
F-250 WARHORSE
F-250 WARHORSE is offline
F-250 WARHORSE has a good reputation on FTE.F-250 WARHORSE has a good reputation on FTE.
I seem to be getting way better mileage and better characteristics out of premium than the regular gasoline, like enough to save money by buying premium. Anyone else tried this?
Old 01-26-2012, 07:05 PM
skibber's Avatar
skibber
skibber is offline
skibber is gaining momentum as a positive member of FTE.
I'm skeptical. Too bad you don't have the numbers to prove it.
Old 01-26-2012, 07:11 PM
77393's Avatar
77393
77393 is offline
77393 is starting off with a positive reputation.
I have a 2005 Lariat with the 5.43V and it runs alot better on premium and seems to get better milaage as well. I don't keep track of milage, whats the point if your going to drive trucks.
devino246's Avatar
devino246
devino246 is offline
devino246 has a superb reputationdevino246 has a superb reputationdevino246 has a superb reputationdevino246 has a superb reputationdevino246 has a superb reputationdevino246 has a superb reputationdevino246 has a superb reputationdevino246 has a superb reputationdevino246 has a superb reputationdevino246 has a superb reputationdevino246 has a superb reputation
The only difference between regular and premium is the resistance to detonation. High performance vehicles require premium because of their increased compression. If your getting better mileage on premium, you've got a slight predetonation (pinging) problem. Could be retarded timing, among other things.
Old 01-26-2012, 07:51 PM
fmc400's Avatar
fmc400
fmc400 is offline
MSEE
fmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud of
Octane has nothing to do with mileage and performance in a stock engine. As devino correctly points out, the ONLY thing a higher octane rating means is that it literally has more octane and less heptane, and can be compressed further before combusting on its own like a diesel engine.
When you say "better characteristics," that's purely a qualitative term. If you truly were seeing some quantitative benefit by putting premium in an engine that doesn't have high enough compression to see any difference between regular and premium, then you have a pre-existing detonation issue. Fixing that and using regular gas will save you more money (and your engine).
Old 01-26-2012, 08:11 PM
Stinky7-11's Avatar
Stinky7-11
Stinky7-11 is offline
Stinky7-11 is starting off with a positive reputation.
Old 01-26-2012, 08:22 PM
77393's Avatar
77393
77393 is offline
I'm sorry, guess its my imagination.
Old 01-26-2012, 08:37 PM
tbear853's Avatar
tbear853
tbear853 is offline
tbear853 has a very good reputation on FTE.tbear853 has a very good reputation on FTE.tbear853 has a very good reputation on FTE.
Maybe it's that extra 30-40 cents per gallon that's causing you to tread lightly on the go pedal that's leading to some slightly better mileage?
Old 01-26-2012, 08:42 PM
Stinky7-11's Avatar
Stinky7-11
You only need to tell that to your wallet! I have done the same
Old 01-26-2012, 09:09 PM
1972RedNeck's Avatar
1972RedNeck
1972RedNeck is offline
1972RedNeck has a good reputation on FTE.1972RedNeck has a good reputation on FTE.
The premium gas around here reeks of ethanol. We get better mileage on regular. Although starting about a year ago most all of our vehicles won't run on regular without pinging. And the octane rating stayed the same.
Old 01-26-2012, 09:11 PM
meborder's Avatar
meborder
meborder is offline
meborder has a spectacular reputation.meborder has a spectacular reputation.meborder has a spectacular reputation.meborder has a spectacular reputation.meborder has a spectacular reputation.meborder has a spectacular reputation.meborder has a spectacular reputation.meborder has a spectacular reputation.meborder has a spectacular reputation.meborder has a spectacular reputation.meborder has a spectacular reputation.
taking my usual role as devils advocate:
it could be that his ignition is unknowingly too far advanced, thus taking advantage of the higher octane fuel.
i've known guys in the past to do this, purposely advance the base timing several degrees to gain power, and run premium fuel to stay out of detonation.
just throwin it out there..... at least he isnt claiming to get 30mpg from his 460
devino246's Avatar
devino246
Really crappy gas leading to carbon buildup and increased compression maybe?
Old 01-26-2012, 09:55 PM
Blue and White
Blue and White is offline
Blue and White is gaining momentum as a positive member of FTE.
On a newer computer controlled vehicle with knock sensor, the computer will provide more ignition advance (sometimes) with premium which improves mileage and torque a bit.
Bascially the computer slowly advances timing until the knock sensor kicks in... it will advance farther with premium.
On a non computer vehicle like a dent, if it runs OK on regular, there won't be benefit with premium... unless the gas formula is different (ie less alcohol).
Old 01-26-2012, 10:05 PM
77393's Avatar
77393
77393 is offline
Thank you sir. I knew the 5.4 3V liked premium, just was not sure why. Thank you for explaineing it, I knew I wasn't crazy.
Old 01-28-2012, 07:22 PM
F-250 WARHORSE
Mine has trouble starting on a cold morning with regular, it is a 10+:1 460, not a "stock dent" at 6000' elevation. With regular it starts and dies, starts and misses, with premium, it fires right off, no dying and no missing, hit the key and it its good to go. When warm, it sometimes has to crank a while to take off, from that cheap gas with e10 blend boiling and fogging out the carb. Premium doesn't do this either. And finally, my 84 honda xl600r kick start does not like anything less than 91. Your leg will wear right down at 5:00 am starting that thing on 85 octane. It won't run on it, 91 never had an issue. That motor specs to 8.5:1 comp. and it is original. I don't buy that 85 and 91 octane are the same just more resistance to pinging. I beg to differ, if I fill my bike up at those pumps that have one hose for all 3 fuel grades, I will have a well conditioned leg by the time I get new fuel, I go to one of the 3 fuel stations left in our town with seperate hoses for the fuel grades. I think when you buy only 2 gallons you probably get 1/4-1/2 gallon of the cheap stuff to purge the line, almost worth asking the guy next to you if you can pump a gallon into his car free of charge to save my right leg.
Next study I have conducted is on Husquvarna chain saws. The cheap gas leaves deposits on the plug, plugs the spark arrestor, and again, you better eat your wheaties to start those things on a cold morning in the mountains. Run premium, or even better, av gas, problems solved.
Quick Reply: Does anyone see huge improvements in premium vs reg. unleaded?
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
