1992 f150 regular cab ford 8.8 to ford 9inch rear end swap?
There is nothing reverse about the rotation. They rotate the same way as any other driver side drop front axle.
It's called reverse spiral.
C-clip eliminator kit - problem solved!
Cut from another web source:
One way to achieve more driveline clearance and reduce universal joint angle is to use a special center section with reverse rotation ring & pinion gears. Both Ford and GM have used this design in the front of 4WD vehicles for years. A reverse rotation ring & pinion has the opposite tooth spiral on gear teeth that a standard rear differential uses. If a standard rotation differential was flipped upside down, the results would be the wheels turning in reverse while in forward gears and in forward when the transmission is in reverse. The reverse spiral on the gear teeth make it possible to raise the pinion above the axle centerline and still drive the wheels in the right direction.
Here is the complete URL: High Pinion Third Members
To your point, yes the reverse spiral cut of the gear teeth are what makes it work, but the term reverse spiral refers to the teeth on the reverse rotation ring and pinion gears. Either terminology is correct in my eyes.
I swapped to a 9 inch in my 93. It bolts right in. But you really should get a 1-1/2 longer drive shaft, but you don't need it. I would get it some people wouldn't.
I personally am one that doesn't think the 8.8 is a bad as every one thinks. But it will in not handle 35 inch for a extended amount of time. I am speaking from a experience not what other people have told me. I went through 2 sets of spider gears with 35 inch all-terrains on my truck. But other then that I had no problems out of it. I think that if you put them on there and just used them on the pavement it would hold up fine for a good long while. but....
For the people that think the 8.8 and 9 inch are same in strength, I have had 38 inch T.S.L.s on my truck since the day the 9 inch was swapped in there. And now the tires and the rear-end have been in and on the truck longer then the 35s were.
So make off it what you wish but I think it is obvious what is stronger.
For my speedometer i moved the speedometer to the transfer-case. It is off though when I am going 55 it is showing 4. yes 4. so I need to play with the electronics some. But I will post results for that when I do it. Until then I hope the info helps.
I was just pointing out a very common mistake. No one is holding a gun to your head to use one term and not the other. If someone cares enough, one is correct and the other is not. If you don't care then don't let it bother you.
Oh, and I have a 9" under my truck too, but I am taking it out. The housing is bent. I am going back to my 8.8, the jy doesn't have any 9"'s anymore.
#28
Just so you know...I exploded a 9" all over Tellico (NC) with my 78 F-150, a built 400 and 35" tires. Broke both bearing caps right off the third member while climbing a really not that big a rock. I'd say you actually probably want a Dana 60 or Sterling axle, even though this means a change to 8 lug wheels.
#29
#30
If your on a budget like everyone else then I'd buy 4:10's for the 8.8 since you've already got the front all set.
