First look!
First look!
205.jpg picture by H_A_S_R - Photobucket
Here is my `58 after the final mock up. It has an `86 Jag ifs sunk 2" up into the frame and a `94 Mark VIII irs set as high into the frame as possible without raising the bed floor. The rockers are 1" off the ground. Obviously the correct wheels and tires are not installed. When they are, the truck should come up about another inch. The aluminum `94 4.6 DOHC engine is also used in this build.
John
John
John
John
Hi John,
Lookin' good!
I have the same parts for my 56, except using an 89 T-bird SC rear. Not going as low, but tempted.
Also attracted to the 4.6L as an option. Although I am also considering the supercharged V6 from the T-bird. (I know, I know, why on earth a V6. I am getting continually razzed about that particular choice.) However, wondering if you or anyone out there might have any good links to builds that detail installing all the computer related stuff to these more modern engines?
Thanks,
John L
Lookin' good!
Thanks,
John L
I bought an EVTM manual from Helms for my wiring. It looks like it's gonna be pretty simple. I'm sure there are aftermarket harnesses available. As for the supercharged V6. AWESOME! I always dare to be a little different too. I had thought about the Supercoupe engine but I wanted an engine that would fill the monsterous engine bay but still got good mileage. I bought a complete (slightly wrecked) Mark VIII for use as my donor car, stripped everything possible, then sold or scrapped the rest. It was a pretty economical way to get the combination I wanted.
It does need to be moved forward. Some guys go 1 1/2", others go 2". I think it depends on the look you want and the tire size. I moved mine forward 1 1/2" inches. I will be running 26" tires on mine.
John
Maybe I will fit two V6's in there! I believe the stock HP's are similar for both. I have another option in the wings, and that is that my current 2003 F150 pictured in my avatar has about 126k miles and I may talk my accountant into replacing the engine with something with a little more umph. Then voila, its two more cylinders on the cheap. But there is just something about doing something a little unconventional...
John, can you provide a link to the book you mentioned by Helms. (specific to the V6 or 4.6)? Thanks, you can be sure I will be following your build!
John L.
Just starting to get into this forum, so excuse me if I am stealing this thread. Also, like the idea of posting the future build info in the signature, so getting a lot of ideas from your posting - Thanks!
John L.
They are model specific books. Just enter your info. Year, make, model, etc. The books aren't cheap but they are worth every penny!!!
Thanks! I've been collecting my "vision" of this truck for over a year. Since The chassis is coming along fine, it will be blown apart and finished. In the meantime, there are MANY body modifications to be made. Some are very subtle, some are not. All should work together well to complete my vision of how this truck should look!
What's nice about the Jag IFS and the Mark VIII IRS is the extreme range of travel. Both will go up 6" easily to avoid obsticles.......
