96 F350 Dually front axle sag...Ball joints?
This is a 240k mile truck with oem dually wheels and has the diesel engine. Needs a front end alignment and pulls hard left while driving. When parked with the wheels straight and looking towards the truck from a distance, i happened to notice that the steer wheels arent directly vertical. There is a little more on the bottom that is outward than the top. Almost like worn ball joints on the upper front end that would allow the top ball joint to be word so that the wheel drops inward toward the engine. I havent jacked up the front end yet, and am going to take it in for an alignment to see if this is correctable. A few years ago i had a 94 that we replaced the ball joints so i know what it entails. Although it was from a different realization than what is described here. Any help is appreciated !!!!
This is interesting as my '95 F-150 4x4 is doing the same thing. When looking straight on from a distance front tires look something like this: / \ where they are closer to each other at the top than the bottom. I've got worn ball joints on my '69 Bronco D-44 and it's awaiting the time for the replacements and those tires are straight up and down even with the worn ball joints: | |
If worn springs would fix the problem with the '95 I'd love the excuse to throw some MOOG CC844s under it to bring the front end up level with the rear!
Alignment won't fix weak springs either.. If your front end is sitting pretty close to the bump stops there is a good chance the springs are worn out, especially with the weight of the diesel engine sitting there all these years.
You need to check the ball joints before wasting money on an alignment.
These trucks do look kinda bow legged after backing up.. So look at the tires after pulling forward about 10 or so feet before you condemn any thing.. Another thing, if it has too much toe in it will make it look bad even if everything is OK.
Very good point. I typically back into my parking spots both at home and work. This is my first TTB truck so I'm learnin'!
I will assure your truck is a cab-n-chassi model?
I sure did back in and only noticed it then, so while it does pull harshly to the left and considering mileage i was already pricing ball joints as the diesel motor is quite heavy anyway and the f350 coils seem tired. This was a dually extended cab truck that has the cab replaced to a standard cab. Thankx again for all the input from everyone.
Got the results today and Lazy K was right on. Wasnt able to perform an alignment since both upper ball joints are bad, they also recommended right drag link outer tie rod, and left and right radius arm bushings replaced as well. So now its time to do at least the upper ball joints. Who would be the best resource for parts? Dont just want order any ball joints from auto zone since they sell so much chinese junk and dont spec test at all. Thankx!!!!!!!1
I would put in XRF parts. They are a better quality than the Moogs, have a better warranty and WAY cheaper
http://www.thetireclub.com/content.w...RUCK_KITS.HTML
Check out the radius arm bushing after backing up.
