proper way to remove head lights
01-23-2012, 06:03 PM
looking for the correct way to remove the head lights.
i dont have the sealed beam so the other kind with bulbs.
99 e250
01-23-2012, 06:43 PM
Reach behind light, dis-connect harness, twist and pull.
01-23-2012, 10:14 PM
no room to get to harness, they have to pop out some how.
also how do you aim the lights? they need to come up a bit.
01-24-2012, 01:05 AM
there should be two tabs you lift, then the headlight should easily come out, then unscrew the bulb base and your done. Shouldn't take more then 4mins each side.
christurney77
1947 and Older Ford Trucks
02-01-2013 12:47 PM
honeys 29
11-24-2010 01:00 AM
Bigcat350
02-19-2009 11:40 AM
Superduty krazy
09-26-2007 05:53 PM
Dan Robertson
1983 - 2012 Ranger & B-Series
03-10-2007 11:56 AM
