Brake line flush
Old 01-31-2012, 10:05 PM
Y-oh-Y's Avatar
Y-oh-Y
Y-oh-Y is offline
Brake line flush
I have a 60 f100 that is getting a new brake system, everything is being replaced but the brake lines. I am planning on flushing the existing lines out with a large syringe and colman lantern fuel. I have been told that colman fuel dries leaving no residue. Master cylinder, hoses and wheel cylinders have been removed.
Any thoughts as to a better way to do a budget flush ?
Thanks, Mark
Old 02-01-2012, 07:10 AM
thundersnow70's Avatar
thundersnow70
thundersnow70 is offline
i have never heard of the coleman fuel flush. if i was doing it, i would just flush the lines with more brake fluid. something about putting a fuel in the brake line that doesnt sit well with me. if you do go with the fuel flush, i would blow them out with compressed air when you are done. might not want to be smoking when you do it.
good luck!
Old 02-01-2012, 10:20 AM
GB SISSON's Avatar
GB SISSON
GB SISSON is offline
I've always used alcohol to clean brake parts. I think that is the recommended solvent. Coleman fuel (Dad called it 'white gas') is a petroleum product, and any left behind is bad for your new rubber parts. Alcohol, like coleman fuel leaves no residue. My .02
Old 02-01-2012, 10:35 AM
Grubbworm's Avatar
Grubbworm
Grubbworm is offline
I use denatured alcohol when I flush mine every couple of years. I get it at The Home Depot.
Old 02-01-2012, 01:27 PM
Y-oh-Y's Avatar
Y-oh-Y
Y-oh-Y is offline
I thank you for your thoughts. I figgered sometimes it's better to go with whats known than to go with a maybe. Alcohol it was, worked just fine.
Thanks, Mark
Old 02-01-2012, 05:13 PM
Rusting-Nuts's Avatar
Rusting-Nuts
Rusting-Nuts is offline
Ahhhmm....I think just using brake wash might be a good thing to use since that is what it is made for. But I'm with thundersnow70 on just using new clean brake fluid to flush the lines. I wouldn't want to contaminate the system with anything.
Good luck, Jack
Old 02-01-2012, 05:39 PM
Y-oh-Y's Avatar
Y-oh-Y
Y-oh-Y is offline
Good luck, Jack
The alcohol is a lot more fun, just fill the system, drain and then light a match. no more debris and it dries the system at the same time.
Old 02-01-2012, 08:12 PM
spurredon's Avatar
spurredon
spurredon is offline
That sure makes me feel like a slacker! I have never flushed the lines except at replacement times. Of course, here in the lovely NE, that don't last that long anyway! They rot from the outside!
Old 02-02-2012, 07:48 AM
Grubbworm's Avatar
Grubbworm
Down here it is the high humidity that gets to them. The humidity gets absorbed into the brake fluid and causes issues from within.
Through the years I have found that the more preventative maintenance you do the less you have to do in repairs.
Old 02-02-2012, 03:43 PM
1959_f100's Avatar
1959_f100
1959_f100 is offline
i would definatly re flush them with brake fluid after using anything else just to make sure you get it all out. you should not use regular shop air to flush out brakes.
pholmes350
13
11-30-2017 10:41 PM
Outlaw56
44
04-10-2017 09:57 AM
charles09
01-31-2010 02:59 PM
randrford
07-27-2006 03:12 PM
badass truck
03-22-2004 11:27 PM
Quick Reply: Brake line flush
