New here saying hello.
Old Jan 23, 2012 | 07:00 PM
sport-trac's Avatar
sport-trac
Hey all,
been a Sport Trac owner for 10 years now, been a great truck but now starting to get some issues. Got some great info here a couple years ago about replacing the electronic window switch that went bad early on drivers side, was easy to replace and part cost me $60 if I remember correctly....saved me about $200.
I just had a PCV Hose replaced when codes P0171 bk 1, P0174 bk 2, caused CEL to stay on. truck began lurching while at stops etc. and had a burning smell. hose was found to have a split. while it took care of the lurging and CEL, the burning smell is still there, and just the other day I could see white smoke coming up from around the left back of the engine area when I lifted the hood.
truck is running rough and noisy, thought some one might have some advice.
Thanks in advance.
Old Jan 23, 2012 | 07:53 PM
shorod's Avatar
shorod
Does the burning smell like oil, or is it more sweet? Generally "white" smoke would be burning coolant, "blue" smoke would be burning oil, and "gray" smoke would be rich exhaust. The burning could be due to a leaking valve cover gasket that's allowing oil to get on the hot exhaust.
Since you also have some roughness and noise, maybe you have broken exhaust manifold studs or a cracked exhaust manifold that is allowing exhaust to escape before the oxygen sensors. The sensors could be reading this as a lean condition. Have you checked recently for codes? If the O2 sensors think it's running lean, they may be telling the PCM to dump more fuel in causing gray smoke to come through the crack/gasket and probably also causing a drop in fuel economy. Have you witnessed an exhaust tick before to know if the noise you're hearing is an exhaust leak or not?
You could also have a bad intake manifold gasket that could explain the roughness, but not so much the smoke.
-Rod
mihnen
Feb 11, 2018 03:06 PM
balboni
Jul 23, 2015 11:55 PM
lemonshindig
May 6, 2010 07:32 PM
bbrinkley
Apr 17, 2006 09:47 PM
WoomaHodal
Jul 24, 2005 04:30 PM
