intermittent....uh whirring sound front end....
2000 7.3 ex
wierd noise intermittent in front end sounds like a tire is rubbing and then goes away....no rhyme nor reason straight stetches or going around a corner....the beast has a 4inch lift and 315 bfg's so i am acustomed to wheel rub at full lock but same sort of noise comes and goes going straight. nothing obvious rubbing... idears? thanx
X2 on the needle bearing. When the sound starts, shift it into 4WD (without the hubs locked) and see if it immediately goes away. If so, it's likely a bad needle bearing. It's probably taken the axle stub shaft with it. If that's your problem, the sound is the stub shaft intermittently getting caught in the hub rotation and rattling around in the needle bearing.
Plan to replace the needle bearing, stub shaft and u-joint
Nope are hubs are unlocked/auto position
Not fan clutch
I know good excuse for the new hubs while im in there.
It makes sense because last dump of snow a while back
Momma was yacking that she thought 4x4 didnt engage even though she locked up.hubs.....i disregarded as her being crazy....maybe shes just crazy like a fox....
Not fan clutch
Grease & Gravel
1983 - 2012 Ranger & B-Series
03-24-2017 09:42 PM
