4x4 working or not?
You should be able to tell easily in snow. Put the transfer case in 2wd and stomp on the gas, then shift into 4wd (lock hubs) and repeat. You should notice a big difference. Or find a parking lot and go into 4wd and turn the wheel all the way left or right and drive in a circle, you should notice some jerking,pulling in the wheel. Only do it on snow though, really hard on things when its on dry pavement.
if on snow hold the brake and attempt to do a "burnout" if the rear tires spin then ur in 2wd. if the whole truck moves then your in 4wd or your front brakes dont work lol
yeah locking the hubs might help...
i made that mistake one time, after 7 years of driving my jeep with auto hubs - i forgot all about manual hubs... felt like a jack *** when i called my friend frantic that the 4x4 didnt work
otherwise you should definably be able to tell... try putting it in 4x4, drop it in reverse and give it a goose on the throttle. then back to drive/1st gear and you should be able to tell if your locked in
Received 3,103 Likes
on
You should be able to shift on the fly from 2wd to 4hi, don't think I'd do it under throttle.
For example, if you have 4.11 gears in the rear, the front will have 4.10s, or if you have 3.55s in the rear the front will be 3.54.
So now we know the 4wd works when you get out and lock the hubs. How do you know the gear ratios between front and rear are different? It takes a peek out the window to know if your front axle is live while spinning and only a glance will tell you if you have auto or manual hubs. So how do you know the front and rear have different gear packages..did you do a swap?
