ReadyLIFT SuperDuty Anti Wobble Trac Bar Install
I think Icon and a few other lift kit companies make an adj trac bar for the 1999-2004. I was just asking if this particular company made one for my truck!
...really lots of good info here.
When I purchase my 2012 F350 in the next couple of months...I am going to install a 2.5" level lift. At that time...I will def be replacing the OEM tracking arm...with an adjustable type.
IMHO...a dual steering stabilizer setup only masks the death wooble. I prefer to eliminate it. Will still use a stabilizer...but probably OEM or Bilstein 5100 single.
biz
biz
When comparing bars, this one is my choice...
Baja Customs Trac-Inator Ford SuperDuty F250/F350 Track Bar
Old thread but I thought I'd report:
I just bought and received my WC Motorsports Anti Wobble kit today. Very nice set up from what I can tell.
For those who asked earlier... (I know this is an out date thread) the WC kit and the Ready Lift kit are the same kit. Per a conversation I had with one of the owners of WC, they make the kits for Ready Lift.
This may be common knowledge but I thought I throw that out there anyway!
Should have the kit mounted today.
Cheers
Nemi
Cheers
Nemi
I did eventually buy the bar for my 08, it did do what they said it would do, I would never spend that much money again especially when the Icon bar is way cheaper. It was a pain to install in my driveway, a lift is mandatory or some way to lift the front so you can get the air gun under that ball joint.
I'll admit the 700 was a tough spend! It was an impulse buy as it was the only bar I could find that actually returned my track bar and drag link back to parallel. My bump steer was ridiculous. Even with a dual stabilizer the truck was no longer enjoyable to drive. Admittedly I have yet to experience the death wobble... even after a 6" lift and 35s.
I will eventually get bilsteins to replace the current stabilizer as well as all 4 shocks. After all I have spent I could have gone with one of the top lifts to begin with. Chock this up as a lesson learned!
Cheers
Nemi
Cheers
Nemi
the front axle wobbles because some computer retard decided that a ball joint was good at holding the axle still. I thought a ball joint moves abck and forth? o thats right it does good going frod. Basically when you hit something in the road it causes the axle to move side to side because the ball joints moves side to side.
Offer for the Ford Truck forum members.
Part numbers 77-2000 and 77-2001 I will sell at $595 delivered for simply calling and mentioning you saw the offer on this thread.
