I am building a 56 big window, that will be using a 69 thunderbird subframe, and an 89 super coupe irs[/IMG]
I understand about using what you have, but using a much later donor will make your life much easier. Say if you use a CrownVic sub frame and need wheel seals or brake parts... you can go right down to the local parts store and pick them up, around here they would have to special order parts for the 40 year old front end. Also modern suspension, steering and brakes are much improved over the bird. BTW, the bird would make a great cruiser also... just sayin.
you are right, but I am able to buy everything for bird front end from the local parts store. I had this and wanted to make use of it. Besides the brakes on the bird are huge
