borg warner 1356 jumping out of gear
Hello all,
i have a 1356 in my 89 7.3 thats been jumping out of gear like crazy, i tore the ******* down and found my range disc had worn thru the plastic guides and started eating the aluminum range fork. I bought a new range fork for a reasonable $50, when i put it back together it seemed to have cured my problem. i drove it 7 miles and it started jumping again wtf? it wasnt "as bad" as before but its still very frustraating. does anyone have any advice or have run into this problem before? your input please
thanks
thanks
Ha ha no im just an idiot, i had just finished watching south park bigger longer and uncut so i made my profile SADDAM HUSSEIN and said i was from Kuwait lol. so your transfer cases, what condition are they in???
and its not jumping completly outta gear but when going downhill or quickly decelerating it makes a nasty clunking sound. and thats in 2wd.
The nasty clunking sound might be just worn out gears....how many miles are on it? Whats the truck look like? Whats the history? My transfer cases are all in great shape....the one I pulled from the 84 was hardly used....it still had that nice whine you hear from new cases that are breaking in....you could hear it doing its job and it was nice to know lol.
Received 3,106 Likes
on
I had a problem with mine where it jumped out of 4x4 once with quite a bang! Then I couldn't get out of my driveway... thought it was just the ice and crappy tires as the lever was still in 4x4 position. Later found out the front axle no longer turned in 4x4 hmmm... Tore it down and found a problem with the metal plate that pushes the selector forks. I don't know what exactly that part is, but its attached to the lever, and rotates when you shift the transfer case. It was a little loose on the shaft, and popped sideways so it would still rotate, but no longer contact the selector forks to shift. I think I ended up shimming it slightly with a washer so it couldn't wiggle around and haven't had any issues since. This could be part of your problem.
bent shift fork could be the case. it only does it in 2wd and doesnt do it in 4wd so the chain isnt spiining at all in 2wd. it could be shift fork or also the range disc, i never replaced it.. thought it look alright. thanks for the input i really appreciate it.
I maybe in need of a T case if I am unable to rebuild mine
nothercrash
04-01-2011 05:34 AM
sbrimlow
07-16-2007 08:15 AM
Steve A
12-08-2004 08:35 PM
78bigunns
11-18-2002 05:03 PM
