Store Your Battery Safely This Winter with PowerArmor Solar
Unboxing the PowerArmor Solar!
Now that it’s getting frosty outside, it’s time to start thinking about storing your trailer and batteries for winter. Instead of having to bring your batteries inside your home, with the PowerArmor Solar you can leave them safely on your trailer. A good example of this is forum user Restcure, also known as John, who needed extra RV battery storage and plans on leaving his spare battery stored on his trailer.
–John, restcure.ca
Installing the PowerArmor Regulator
Hey John – keep that 10-watt panel in a somewhat sunlit location and it will maintain your battery charge! John benefits from having extra battery power for his trailer and you could too. An access port allows for electrical wires to pass through the side wall of the box so it easily connects to your electrical circuit system. Since he has just a single battery installed in the PowerArmor at this time, he also needed to get a regulator to protect his battery from overcharging.
–Restcure, aka John on forestriverforums.com
Look at how awesome the solar panel is!
Torklift’s battery box comes with a solar panel from the leader of RV solar power, Zamp Solar. This solar panel actually has the ability to extend battery life fourfold. Let us repeat that: your batteries can last up to four times longer when they are maintained with the PowerArmor Solar. This translates to avoiding the time and money of re-purchasing your batteries. The solar panel trickle charges your battery even when there is no direct sunlight, and keeps charged batteries at the optimal level to maintain healthy RV batteries. This locking storage box also comes with a corrosion proof mat to prevent damage to the PowerArmor from potential battery leaks.
Further PowerArmor Solar features include:
• Prevent common and expensive storage/battery theft (lock included)
• Maintains charge increasing the longevity of the batteries up to 400% to avoid premature battery replacement (solar only)
• Dual use for securing batteries and other gear
• Bolts to your RV, camper bumper, truck, van, etc.
• Heavy gauge diamond plate aluminum for maximum durability
• Designed specifically to access RV batteries avoiding interference with your RV
• Uses a 10 watt solar panel (solar only)
• Comes in bright tread diamond plate featuring black high impact powder coat frame
• Multiple box sizes available holding up to five batteries
• Adjustable dividers for custom size compartment storage (PowerArmor Max only)
• Acid neutralizing battery mat to avoid corrosion
• Legendary Lifetime Warranty
• Proudly made in the USA
The PowerArmor Solar fully installed
If you’re interested in purchasing the PowerArmor Solar from Torklift International for extra battery storage, make sure to visit one of our Certified Dealers near you here. To contact us for more information, reach us at support@torklift.com or call our tech support at 800-246-8132. We are more than happy to help you.
Written by: Kerstin Stokes
__________________
Torklift International – Towing, Suspension, Tie Downs, Steps
Call me direct: 1-800-246-8132
Visit our Blog: http://www.torklift.com/blog
Torklift Sheryl
Vendor Specials, Discounts, Product Announcements & Group Buys
01-29-2019 01:09 PM
Torklift Sheryl
10-18-2018 04:56 PM
Torklift Sheryl
04-24-2018 03:24 PM
Torklift Sheryl
08-01-2017 04:32 PM
Torklift Sheryl
07-19-2016 01:01 PM
