1999 F350 w/ 12V, twins, NV5600 - $15,000 OBO
Year: 1999
Make: Ford
Model: F-350
Price: $15000
Mileage: 258000
Color: Black
Private or Dealer Listing: Private Listing
Location (State): NY
Transmission: Manual
Drivetrain: 4WD & AWD
Color: Black
Engine: 12V Cummins
Truck has 12V conversion with pretty well built engine. engine build reads as follows:
fly cut pistons
o-ring head
new valves
Hamilton valve springs, keepers and retainers
24V lifters
Hamilton 181/210 cam
Kenny's Pulling parts adjustable cam and pump gear
Kenny's pulling parts billet timing cover prepped for waterman or hilborn pump
Machined dampner
S351, 0 miles since rebuild by Columbus Diesel Supply
HX60, 0 miles since rebuild by Columbus Diesel Supply
Interturbo piping is v-band setup
370 Marine Injectors
024 Delivery Valves
Remote mount oil filter adapter
New Oil pan and gasket
New rear main seal
New rear cam plug
New throw out bearing
South Bend 3850 dual disc clutch
Electric fans
Pyro Gauge
Two boost gauges (one for each turbo)
Truck has a hybrid np273 transfer case that mounts to the NV5600 while keeping the non-slip yoke of the fords
Now for the bad:
the bolt holding in the KDP tab backed out, got caught between the cam and timing gears, snapped the cam, bent all the pushrods, and generally did extensive damage. D&W diesel in Auburn, NY replaced the cam, lifters, pushrods, gaskets, gears, valves, valvesprings, etc. Truck was leaking pretty bad so I pulled it off the road to rebuild the turbos, replace the rear cam plug and rear main seal. I also got all new oil lines for the turbos, and had a new pan made with oil returns for the turbos added.
To finish:
oil lines need to be assembled and installed, the lines are all there with the ends
inter-turbo manifold needs to be finish welded and wrapped and/or ceramic coated
truck will need to be tuned, timing is retarded right now, and needs to be advanced (easy with the adjustable gears)
New battery cables need to be made and installed, all other wiring is clean and ready to go
The truck should really have a wastegate installed to help control EGTs, and for spooling the atmospheric turbo.
For someone with the right skill set, tool set and shop space this is probably a weekend job to get this back on the road.
I don't want to sell, but the truck has been off the road all winter, and frankly I need to get myself into a reliable vehicle again. With spring here, I will likely keep working on the truck, so this is a chance to pick it up while its still a 'project' and finish it yourself. The engine parts alone would make this truck a steal. I'm open to realistic offers, and can provide more pictures if needed.
best way to contact is through email.
boggerted
18
03-19-2012 11:41 PM
HemiEater
10-16-2011 05:49 AM
