Cold Start and Fuel Leak
2006 F350 With 6.0 Diesel
Was having a cold start issue so after checking out the FCIM and finding it bad, I replaced it. Its better but still having issues with cold restarts in the morning.
The other thing I've noticed is a fuel leak draining off the backside of the motor. I cant seem to locate the leak on the top of the block, seeing as I'm guessing its coming from the top.
Any ideas?
Any ideas?
FPR housing is with to the upper fuel filter housing
Take out the 4 torx screws but hold on to the cover theres a spring in the lower half of it
And number 5 lower picture
Tried to get one more pic but it wont work right now
Theres also a plug in the fuel rails at the back of each Head
But this housing is more common spot to leak
Sounds like a pretty good leak especialy if it wont start
Hope you get it fixed soon Low Fuel Pressure will Kill your injectors and if its leaking its probably way low on pressure
If you need a new keyhole gasket at the FPR you might as well put the Blue FP spring upgrade in and Kill two birds with one Stone the blue spring will keep FP alittle higher and save your injectors in the long run
I'm So Tired of Fixing this thing I'm Seriously Considering a CUMMINS transplant!
What Do you expect for a Big POS Just Kidden LOL
This 6.0 Needs to have gauges to watch some things with if you just drive Blind and something goes out 9 out of 10 other stuff will Fail and you have a cascade of Failures
But the Folks that study up and watch there Gauges seem to be Problem Free maybe a Part Here and there
ODDS are Your Batterys took out your FICM those 2 Dam neer go hand in hand see what I mean But if you could have seen the Batterys/Alternator starting to fail you may very well would have saved your FICM.
My truck runs Like a Scalded Dog but I keep Right on top of things going out. B4 1 thing Leads to another
I also do my research before I buy a replacment part and find out what everyone has had Good Luck with like some parts OEM is the Best other parts After Market parts have been Improved over OEM. I also research the problem out sometimes theres more to a PERMINATE FIX than just changing the Broken Part out other areas need Attention for a PERMINATE FIX thats just my .002 worth
77k- EGR Valve
85k - 6 Injectors and Rear Main Seal
89k - Glow Plugs
99k - Short Block
The dealer replaced the block because they couldnt explain why #2 & #6 had no compression. Bet they never checked the heads!
With a Short Block they put your Original Heads Back or thats Normaly what you get with a Short Block
A long block would come with new heads,Valve Train, camshaft,oil pump ect....
Here is a Good thread on the Blue spring Mod with part#s ect...
https://www.ford-trucks.com/forums/1...ue-spring.html
Looks like your a good canidate for the Blue spring upgrade since you had to replace 6 injectors
