6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Gearbox Z DPF-R Programmer
Old 06-11-2016, 10:54 AM
jake lieberman's Avatar
jake lieberman
jake lieberman is offline
I have just received the gearbox z dpf-r plus for my ford f250 2009. I have installed a 4in turbo back Flo pro exhaust with a egr delete kit. I have a check engine light on with codes popping up like P0405 exhaust gas recirculation p sensor a circuit low
P1335 exhaust gas recirculation position sensor minimum/maximum stop performance
P0488 exhaust gas recirculation throttle control circuit A range/performance
P041d. Exhaust gas recirculation temperature sensor B circuit high. And I'm not sure how to solve the check engine light. Can anybody help?
  #62
Old 06-11-2016, 11:16 AM
BROWN DOG KTM's Avatar
BROWN DOG KTM
BROWN DOG KTM is offline
Did your New Exh pipe come with bungs for Sensors ?
Did u drive it with the new exh BEFORE the Gearbox Z install ?
  #63
Old 06-11-2016, 08:09 PM
Greg B's Avatar
Greg B
Greg B is offline
Did you plug the exhaust sensors in after the pipe install? Did any of them get damaged during the removal from the stock parts? Did you install the elbow when you deleted the EGR? If so, did you install the resistors in the EGR plugs of the harness?
  #64
Old 06-11-2016, 08:17 PM
bubba.whit6.4's Avatar
bubba.whit6.4
bubba.whit6.4 is offline
I ran the dpfr for two years with a pipe with no bungs. I had no issues.
  #65
Old 07-11-2018, 12:27 PM
Torkman's Avatar
Torkman
Torkman is offline
DPF-R 4.1 from GearBox Z
Ordered and installed the basic delete kit form Diesel ops that comes with the pipes and the Gearbox Z programmer. After install, keep getting a "Low Fuel Pressure Warning." Called Diesel Ops who had me call Gearbox Z. Sam in their tech support said they are aware of the problem and do not have a solution. Told me to take it to Ford to have it programmed. He said that I have one of the trucks with a low pressure sensor on it and their program does not fix that problem. He said only a few trucks have that sensor. I do not believe that is true. My truck is a 2013 bone stock F-250 Platinum. I asked to speak to his boss about it and he said the boss will not talk to me about it. He said they know about the problem. I asked why they do not tell the customer about it prior to buying and he said he did not know why. Basically, STAY AWAY FROM ANYTHING GEARBOX Z SALES!!!!
I told him I would be putting this on the Forum and he said "go ahead...maybe it will force it to be fixed." I called back to Diesel Ops and talked to Jeff. He is trying to figure out what has happened and why they are selling a product that has a known problem.
Maybe a different tune would help?
  #66
Old 07-11-2018, 02:49 PM
senix's Avatar
senix
senix is offline
Received 1,415 Likes on 1,010 Posts
Your truck is a 2013? 2013's did not come with a 6.4.
  #67
Old 10-05-2019, 08:50 PM
arl8733's Avatar
arl8733
arl8733 is offline
4wd Low
Tow/Haul mode with DPF-R
Does the Tow Haul feature work as normal with the DPF-R installed and should it be used?
  #68
Old 10-06-2019, 06:12 AM
senix's Avatar
senix
senix is offline
tow haul mode will work fine. Use it, it provides some engine braking and changes the shift points while towing.
  #69
Old 10-14-2019, 03:09 PM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
yep
Various folks have had low fuel pressure errors with this kit.
James Mckinney
04-06-2017 04:36 PM
Thasilver_6.7
07-18-2013 07:55 PM
Chalkie
06-14-2013 11:41 AM
dwilliamsceg
17
09-15-2010 07:23 PM
c dogg
11-05-2009 02:00 PM
Quick Reply: Gearbox Z DPF-R Programmer
