Fuel Pressure Test Gauges
Shucks... the top of the regulator housing stripped out on me while I was adjusting my regulator. Got a new Aeromotive on the way! Was actually able to rig it temporarily... took the top off and put a nut on the inside of the housing to hold the main adjusting screw tight and then worked like crazy to get the top on while compressing the spring and trying not to screw up the gasket.
Can't find an adapter to go from a Schrader valve to something else... anybody know of one? Or, are there other fittings that'll accomplish the same thing?
Jonathan... here are a couple of links to companies who provide fittings which should work for you.
CD Valve
Fittings_Adapters
Amazon.com: Caspers 107133 Schrader Valve Fuel Press Gauge Fitting: Automotive
AirRideFittings.com
CD Valve
Fittings_Adapters
AirRideFittings.com
AllaboutMPG
12-18-2014 11:36 AM
2006powerstroke90
12-13-2011 06:08 PM
