1975 f150 360 to 460 engine swap question
On mine I used the 460 Econoline Isolators and cut 3x3 and 3x2 silces of Box Tubing which were drilled for the Isolators and welded to the cross members.. you could also buy the 460 mounts from LMC truck....
LMC Truck Parts - Page 31
The 460 perches are a lot shorter , especially the drivers side .
I have a set for sale in the classifieds here . I won't be back until Saturday , but I would gladly post some pics and dimensions if that will help .
Are you running manifolds or headers ? I have a set of 74's that use donut gaskets and the 75's that use a flange on the pipe . Some car manifolds exit out behind #4 into the frame where the truck style dumps down between #3 & #4 . I can post pics of those too .
1984 F-150
09-12-2010 10:37 AM
davelong667
03-27-2004 10:55 PM
