F1 Jag IFS Soft Mount or Weld in
#31
They are made with 1/4" plate and I welded 3/16" x 1" wide barstock around them. welded inside and out. also there are 1/2" pieces welded on the bottom side from the engine bolts to the JAG rubber. If that makes sense. I have wondered about bending those plates under a load. But I have seen less metal in aftermarket mounts. Thoughts?
#32
I don't have pictures of the engine mounts to the frame. You can see that I made them from 10g steel. All the catalog mounts for my engine were full tube mounts and would be a problem with the Jag IFS and the headers. If you can wait until I get back to Colorado in the Spring I will send you some good pictures.
______________________________
46 Ford Tudor - Street Rod
48 Ford F1 - OSC
48 Ford F1 - OSC
#33
#34
I don't want to blow seals in the rack, and I have looked at a ps pressure regulator...$100 and it has to be tied into the high and low pressure lines...alot of extra plumbing stuff!
#36
#37
48 Ford F1 - OSC
48 Ford F1 - OSC
#38
I don't know for a True Fact but have been told that Germany is uber-strict about ANY mods. Can't change tire size or profile to something not approved by the mfr. Can't change ride height more than some small amount up/down. No changes to lights, etc. When I see some of the jacked up 4x4 using 6" blocks under the springs, I think it's not such a bad idea to require inspections, but there doesn't seem to be any middle ground.
#39
Just because you CAN do it, doesn't mean you SHOULD do it!
Something to that effect, but I have seen some questionable stuff too!
#40
#41
I bolted my subframe in, using the stock jag rubber mounts. Pics in my gallery. My frame is boxed using 10 gauge from the front to the rear axle. I had some frame damage so I boxed the whole thing for insurance. I wanted to bolt the subframe in so when I'm long gone someone else can change what I did easily. I think it was easier to make the mounts and drill the holes to bolt it in than it would be to make the mods to weld it. The ride is fine, but of course I can't compare it to anything. I got the jag power steering pump, but it doesn't fit my engine. I removed the pressure valve and transfered it to my current pump, which is a GM saginaw. Works fine.
#42
Remi
#44
Guess I will jump in here !! I am in the process of installing my 86 Jag front end in. I am doing a soft mount. I notched my frame for the crossmember to ride level with the frame. The front mounts I have made some brackets that can weld or bolt in.I need to get it finished but the little woman has me doing some honey do's hardwood floor. If any one wants to see what I have done let me know and I will post them in my Albums.I did have a question on the front mount. On the drivers side it was tweaked. I got it back to the same degree as the other side. but it is still in about 1/2 inch . Any Ideas on that if it will be a problem? The mount is 89degrees vertical same on both sides.
#45
