Coolant slow seeping leak
I have a slow seeping leak and can't seem to pinpoint where it is coming from. I suspect it could be the thermostat housing or one of the hoses, but it does it when the truck is just sitting, colder than a well diggers butt. Could I have a cracked block or a bad freeze plug?
I had a slow leak on my '89 F150. Was the little vent hole under the water pump, usually when a water pump leaks from there, it's time to replace 'em.
I kepted driving it, dripped slowly like that for almost a year, untill one night coming back home, as I turn into my street, I hear the belt start squeaking, and in the driveway, the water pumped just puked everything out.
My '89 had a seep, but it was the timing cover, bottom passenger side under the waterpump passage. Seems the gasket went south, the alumimun cover got corroded and leaked/seeped real slow.
I had to pull it all down, new gasket(put a new chain in too), water pump and all the other little pieces that needed replaced along the way.
b4hntn
1978 - 1996 Big Bronco
06-21-2008 05:51 PM
95xltmud
01-23-2003 01:37 PM
