Aftermarket Gas Tank
I had to replace both tanks in my truck. I bought them from Advance. They are spectra brand. While I had them out I replaced the sending units as well. The only issue had was on one of the tanks the notches cut out for the fuel sending unit were in the wrong place. (They should have been at 9 and 2 o'clock but where at 10 and 3 o'clock or something along those lines. I put new notches in and have had no issues. Been about a year and a half).
I tried to get the rust out of a tank as follows:
- Dropped tank and poured out all gas
- Put in 2 gallons of new gas as well as a heavy chain and sloshed it hard for as long as our arms could go
- Poured that out and put another 2 gallons in awa chain and sloshed again
- Did the above one more time
- poured that out, reinstalled tank and filled with new gas
my tanks rusted out on the top of them. There were holes in the top and eventually they worked their way down the sides. When I got the new ones I painted them with undercoat before installing them.
As for cost I think it was around $100. Spend some time looking around though. Advance (if you go with them) has a lot of discount codes if you google them.
We tried the same thing last year on my '80 F-150 to clean out the tank...dropped it, put gasoline and chain in it, sloshed it around for a while, and reinstalled. It also looked good, but when I rebuilt my carburetor a few months ago I was still able to spoon the powdered rust out of the bowl.
So sometime this winter I will replace the tank. I've learned that if you've got rust in the tank, just buy a new one and save yourself trouble.
Apollo1
11-20-2008 08:15 AM
