55 f100 master cylinder fit
I haven't made up my find yet on a front suspension, whether to keep it stock or do the crown Vic install but I am switching to the 302 engine and t5 tranny to keep the truck as a manual. I need to totally redo the brakes and found a new master cylinder in an ad from a guy near me. It has the bracket and also the 8 in booster to upgrade my brakes.
My question is with the setup I'm looking to run will I have fit issues with the exhaust, tranny, or anything else I'm thinking of that would make the stock master cylinder not fit? Or would I need to move it to the firewall?
Thanks
Mike
Thanks
Mike
I don't think you will have any blocking issues. it will get tight and the exhaust will probably have to run under the master.. least thats the way I am doing it with a larger/later engine & tranny.
is the T5 hydraulic clutch? I have about 7 inches of clearance from the end of the brake arm to the transmission for the clutch connection stuff.
Sam
Sam
Robin86
07-06-2019 09:25 AM
tobyflh
03-25-2018 07:22 PM
bobj49f2
04-08-2010 07:42 PM
1954blueoval
12-03-2004 08:45 AM
DPhillips
04-06-2004 08:35 PM
