99 FORD F350 DRW 7.3L Need some assistance
I live in Wheeling,IL 60090 This is 15 min North from Chicago... David thx for the reply.I just wanne fix my truck in a Diesel mechanic who knows what he is doing.
O ok and i do know a guy in wheeling who does alot of work in wheeling i can't think of the name but i can find out for you when i talk with my uncle but he had helped me with my 99 DRW 4x4 when the 4x4 wasnt working hes a good guy and knows the powerstrokes very well. I will get back to you asap with the name of the shop and where its at with the number.
I just called me local ford dealer and here what they told me that 6.0 tranny cooler cost 395 but they are not sure if it will fit 7.3L. Thay told me that 6.0 cooler for 6.0L engines??? Is that correct? He told me that maybe i need to look for aftermarket one for my 7.3 powerstroke.
Yes the 6.0 Trans cooler was made for the 6.0 liter fords, they are around twice the size of the 7.3 and are considered probably the best cooler for them. Slight modifications to the way you connect it, but installs in place of original. If you went aftermarket something very heavy duty like this Riffraff Diesel: Derale 20,500 GVW Transmission Oil Cooler would be a good suggestion.
I added a tru cool inline with the other 2 coolers on the truck (99 might only have 1 BTW) and I might have got 10 to 20 Degrees cooler still warm though in 100 degree summer heat temps around 200 towing at around 17K gross. I actually disconnected it and I have yet to install a 6.0 cooler I picked up from a salvage yard, but based on everyone elses experiences I expect cooler temps, besides it is just huge in comparison. Since it's been winter my temps haven't been above 120, but will get the 6.0 cooler installed probably in the next month or so, and look forward to seeing temperature comparisons.
So short answer go for the 6.0 cooler, it is what good transmission builders use too.
Diggie likey....! I must say, I want that dually, I think it would be perfect for my summer driver...but,if you're anything like me....you won't be selling it ! Good luck, and stick around...you'll be glad you did. Your wallet may get a little smaller....but your ear to ear grin will surely make up for it. A fellow 6 wheeler....
PS. So i dont understand how come Ford made a better transmission cooler on a 6.0L powerstroke then on a 7.3L? Since most hauling cars or RVs are doing 7.3L? this means 6.0 has better cooler then biger engine like 7.3 that is weird?
Sounds like from What Big Al stated above in the post. Is the 6.0 Cooler is the way to go! The 7.3 is a better engine for sure. But I'm assuming the 6.0 cooler is a better design that the engineers came up with later on. Here is a link from a prior post.
Ford Super Duty 4R100 Transmission - Photos - Four Wheeler Magazine
So which tranny cooler you would recomened for my 7.3L? i haul a 3 car trailer with cars? 6.0 or aftermarket?
I'm no expert, your trans can do it without additional cooling or better cooling, but even stock configurations, similar to me, I fear temps were getting too hot. Cooler temps generally are better on things.
Don't listen to anything they have to say at powerstrokehelp. That guy is a complete moron........
#30
I've heard from some fireman/mechanics that running a 50/50 mix of 5w30 with trans fluid helps it last longer they say they do it in all the ambulances but that's what I've heard has anyone else heard of this? And whwn I worked at the transmission shop in IL my boss said the best fluid for the 4r100 is just straight dex/merc
