M5od into 80 f150
The pedals will not fit, they are different on the 87-up trucks. I believe some people with fabbing skills have made them fit, but I don't know what exactly was involved.
Get your donor, and then go to the junkyard and get some pedals out of a 86-down truck with the hydraulic clutch. 80-thru around 82 had a linkage clutch and that won't work for you.
You will have to cut the hole for the clutch master cylinder mount in the firewall, but other than that it should be a bolt in. Make sure you take the two red/blue wires that go to the side of the c6 tranny and twist them together, or after the swap it won't start. Those are the neutral safety switch wires.
This swap should be worth it in gas savings you will get.
That's true, I am glad you brought that up. You will need to buy a flywheel for your 80 302. It will be a 28oz inbalance. The later one is a 50oz.
If you do get the M5OD, before installing it into your truck, replace the 3 rubber bushings on the shift tower. They are accessible by removing the tranny hump inside the truck, but much easier doing it when the tranny is in your hands.
Ford sells an update kit for this, replacing the rubber plugs with copper ones, that don't fail.
The number 1 cause of failure of these transmission is those rubber plugs leaking, and they only leak as you drive, and you end up running the tranny dry, witch burns it up.
Otherwise, they're good "daily driver" trannys. Don't abuse it to much, and don't tow to heavy with, and you'll be fine. They do have a really tall Reverse gear, be aware of that.
And since your truck is 4x4, you will need a 4x4 tranny.
Heres the plugs i'm talking about. The 3 bumps facing the rear.
What about my 84?
I have a 84 F 150 with less than 100,000 miles on it. Other than some slight rust at the bottom of the area behind the seat, it's in great shape. It has a 4.9L/ 300 straight six engine. It gets lousy gas mileage. I also have a Ford Probe that will soon go to the crusher. It has the top load 5 speed transmission. I was wondering if I could swap the Probe 5 speed into the truck to get acceptable mileage.
Can anyone help me with this decision? Today is the first day that I have considered this, so it is early in my research.
