Changed pre pump filter lot of air bubbles..
I have the same filter and have had the same trouble. You have to risk breaking the glass sleeve by tightening really hard on the two hex metal ends, and then tighten your clamps until you think you're going to crush the tube fitting... that is the only way I was able to get mine to seal completely. Upon close inspection, the ends of the glass tubes are not perfectly flat, and that makes sealing them against the rubber seals inside the hexed metal heads a very difficult task.
I'm replacing my glass unit with the same Baldwin setup I have on my other vehicle.
I have the same filter and have had the same trouble. You have to risk breaking teh glass sleeve by tightening really hard on the two hex metal ends, and then tighten your clamps until you think you're going to crush the tube fitting... that is the only way I was able to get mine to seal completely. Upon close inspection, the ends of the glass tubes are not perfectly flat, and that makes sealing them against the rubber seals inside the hexed metal heads a very difficult task.
I have the same filter and instead of running the risk of introducing an air leak, I just replaced the entire filter instead of taking it apart and replacing the inner screen element. If you read the packaging for the filter, it states that the filter is not for use in a system pressurized above like 30psi (can't remember the number, but it was less than the 72psi I'm running), so I didn't want to take any chances with a filter I am already asking to do more than it was designed to do.
Bob, I understand that, but vacuum pressure is still pressure, right? And the entire system is pressurized to the same amount. Hence the reason my pressure jumped up to 72psi when I installed a stainless return line inside the tank with a smaller inside diameter. Maybe I'm putting too much thought into it.
Imagine using a straw to drink your favorite soft drink. If the straw gets cracked above the liquid level, you will suck air into the straw and not get very much (if any) of your favorite drink. Now imagine having a mouth full of your drink and blowing that liquid back through the straw... you'll squirt liquid out of the crack. In the first case, air gets pulled into the straw because the pressure inside the straw is lower than the pressure outside the straw (vacuum, i.e. suction side of a pump). In the second case, the liquid squirts out because the pressure inside the straw is greater than the pressure outside the straw.
Now in both cases, the real issue is not "pressure" as much as it is "differential pressure". Both liquid and air will always try to move to a lower pressure condition, and that is why the air gets sucked in through the non-sealing quick connect fittings on the suction side of a pump.
What this means is that your filter on the suction side of the pump is NOT seeing the pump's 72 psi of discharge pressure.
Hughesjr84
03-31-2014 10:19 PM
