Sponsored by: Auxito
1998 F150 lighting question
Old Jan 14, 2012 | 10:57 AM
Arratay's Avatar
Arratay
I have a 1998 F150 that I have upgraded to HID lighting. With the way the kit worked I now only use one headlight plugin with a relay pack that draws power direct from the battery for the headlights when there is power at the stock plug. I now have a set of HID fog/driving lights I want to install using the other, now empty, headlight plug. I was wondering if it would cause any issues to draw power directly out of the plug to power 2 HID lights (approx. 70W total draw) or should a go out and get myself a relay to do it. I only ask because with the way I want these lights to function it will get much more complex to wire them with a separate power source, and I know of aftermarket bulbs (PIAA) that draw up to 100W per bulb. Any input will be appreciated, Thanks!
Old Jan 14, 2012 | 04:51 PM
Longdistancetrucker's Avatar
Longdistancetrucker
I don't think you would have any issues...... is there an in-line fuse?
gtex
Sep 24, 2018 06:36 PM
codyjames990
Dec 7, 2016 04:46 PM
DARYLS88STANG
1997 - 2003 F150
Dec 2, 2012 11:00 PM
Sycostang67
Feb 21, 2004 10:59 AM
Sycostang67
Electrical Systems/Wiring
Feb 17, 2004 06:12 PM
