Should I change my 100k mile tensioner?
Old 01-12-2012, 10:31 PM
chetspencer's Avatar
chetspencer
chetspencer is offline
I have about 100K miles on my 05 EX 6.0 and plan on replacing the serpintine belt soon with a Goodyear 4081252 Gatorback. No noise problems at the moment. Should I change the tensioner or let it go? I can get a Dayco 89313 tensioner for about $60. Just curious of what the normal practice is. I have a single alternator so I think I have the correct part numbers. Thanks
Old 01-12-2012, 10:41 PM
bismic's Avatar
bismic
bismic is online now
Received 2,449 Likes on 1,696 Posts
Pretty sure that your belt is 125.8 inches so the goodyear part # is 4081258 (at least that was the case for me).
I replaced my tensioner around 100k - but it didn't need it.
Old 01-12-2012, 10:43 PM
m-chan68's Avatar
m-chan68
m-chan68 is offline
If there isn't anything else that fails relatively seldomly on a 6.0L, I'd have to say is the belt and tensioner. These are the two parts on a 6.0L that fail far less frequently than they do on 7.3L and 6.4L engines. If you feel like replacing them, go for it. If they are not broken or show signs of wear, I wouldn't worry about it.
Old 01-12-2012, 10:46 PM
bismic's Avatar
bismic
I guess I have a good tensioner for sale cheap ................
Old 01-12-2012, 10:51 PM
chetspencer
Encouraging, thanks! My belt "looks" to be in excellent shape but I'm a stickler for maintenance as I make trips to the boonies with my family on the weekends and so figured I'd change the belt just because. bismic the 4081252 belt is 125.825" so maybe they're both compatible?
Old 01-12-2012, 11:03 PM
bismic's Avatar
bismic
The length that should be 125.8 is the effective length - not the outside length.
Old 01-12-2012, 11:04 PM
88f1504x4's Avatar
88f1504x4
88f1504x4 is offline
Powerstroke Doctor
I have replaced two tensioners that failed in the past 3 months one was around 118k and the other was 136k two different trucks.
Old 01-12-2012, 11:05 PM
dukie1877's Avatar
dukie1877
dukie1877 is offline
Just a good habitt of mine for what its worth. When you replace your belt take the old one and Roll it up and stick it in a ziplock bag and put it somewhere in your truck. This has saved me especially if you are a boonies guy like me.
bismic's Avatar
bismic
On a 6.0L?
Old 01-12-2012, 11:06 PM
dukie1877's Avatar
dukie1877
Thanks for spoiling the party Kenny
Old 01-12-2012, 11:07 PM
chetspencer
I cant even get a chance to reply Thanks for the clarification Bismic.
Old 01-13-2012, 12:08 AM
chetspencer
So I checked a second source and still get 4081252 as the correct number for the 05 EX. At this point after all the great feedback I think I'm just going to get a new belt and stick it in the center console. Cheers.
Old 01-13-2012, 01:05 AM
strokin83's Avatar
strokin83
strokin83 is offline
I have to agree with Mchan. I have 291,000 miles on an original....let er ride.
Old 01-13-2012, 04:16 AM
F-250HD's Avatar
F-250HD
F-250HD is offline
Mine was good at 133k, I did replace the belt with OEM..........Motorcaft stuff for me, routinely provides 100k of service without failure. Plugs, replacement wires, (when I needed them) lasted without issue. To me, it's worth the added cost and piece of mind.
Old 01-13-2012, 04:20 AM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
I'll take it. Let me know how much. I FUBARed my tensioner lock and really want to replace it but other than that mine is still spinning at 181K.
Quick Reply: Should I change my 100k mile tensioner?
