Rough at idle with new fuel pump...
06-06-2022, 05:17 PM
on
1989 f150 4.9L. Replaced electric inline fuel pump with a much quieter Bosch. Rough idle right after start. What do I need to check. Thanks
06-06-2022, 05:58 PM
Start here:
06-06-2022, 07:13 PM
on
I'm new single tank, pump and filter. Do I check the pressure at the "pressure test point" and if so what is it supposed to be? Have had several 300's but this is my first EFI.
06-06-2022, 07:26 PM
For the 4.9. It should be 50-60psi at pressure test point
if that is not up to spec: Did you install the filter in the correct direction?
06-06-2022, 07:28 PM
on
Quote:
Originally Posted by
CalypsoOBS01
Thanks Calypso
06-06-2022, 08:27 PM
on
Yes, filter is in right direction
quincyj34
06-25-2013 12:20 AM
DieselVol
09-04-2012 08:55 AM
wuttrd
09-24-2009 10:23 AM
beyermom
09-30-2007 01:37 PM
Jaime_K
Aerostar
13
03-26-2004 08:10 AM
