takes long cranking with 1 cylinder firing.
This is on my new purchase -2000 7.3 with 300,000 miles on it.
The engine seems to be in perfect condition (after fixing few leaks) with no blowby, but when I park it for couple of days -it takes long time to start when I hear it turning over with only 1 cylinder firing, than 2nd cylinder, than 3 cylinders fire and eventually the engine starts running, but for couple of minutes the idle is pretty rough and the engine does not respond to gas pedal. There is no smoke from tailpipe. No codes.
Than the engine starts right away and it has no problem to start following day even at 30F.
My other 7.3 can sit for a month and never does that.
Any suggestions if this is something worth worry about?
Did someone from this forum tipped my truck?
I had it sitting for 3 days and it started right up. It slightly hesitated for 15 seconds, but not a big deal on 300,000 miles engine.
I put synthetic oil in it and I experienced that synthetic is fixing issues on old engines, but that would be on the edge of miracle.
Not that I complain ...
vector
05-14-2018 03:33 PM
Fefanatic
13
08-19-2016 07:48 PM
strokin'_tatsch
08-19-2007 09:00 PM
