1978 - 1996 Big Bronco
MY FIRST 4x4
Old Apr 18, 2003 | 11:25 PM
SouthPCraz's Avatar
SouthPCraz
MY FIRST 4x4
FINALLY my first 4x4 i am 17 and last week i bought a 1978 Ford Bronco Ranger XLT for 1200 dollars it has a 400 in it and a granny 4spd(used to have an auto) this week i am haveing exhaust put on it dual 18"glasspacks with big fat chrome tips replaces plugs and wires oil change and filters next week i am replacing the radiator(its leaking) and hoses i took it mudding already it did awesome i couldnt find anything down at stockton lake in missouri i couldnt go though in it the lmited slip front and rear worked great so now its time for some improvements on the bronco there for i have questions
A.I will buy a lift kit. Will 35s fit under a 4inch susp lift?
B.Will my orignal axles handle the 35s?
C.I plan on using no blocks or add a leafs, do i need anything else other than the parts skyjacker comes with for example extended brake lines steering stuff wiring?
D.Who is the cheapest supplier of lift kits?
Thank you very much if you reply.
Future enhancments on this bronco
4"lift
35" tires
take out the ac unit
confederate flag on the rear glass
chrome out the engine
edelbrock intake and carb
light rail
Old Apr 19, 2003 | 12:35 AM
Stokes's Avatar
Stokes
MY FIRST 4x4
welll you are going to get alot of controversy over lift kits. On a open veiw i have herd about superlift lacking good quality latly so if you ask me stay awayfrom them. skyjacker and many other brands make awsome lifts. i plan to be puting a Dick Cepek lift soon on my rig also. as for extra parts it would be a wise idea to upgrade to exstended brake lines and replace the bushings at the same time. as for the 35s, yes they will fit but it is preaty likely that they will rub. if i where you i would just put a 6in lift on it instead. just my .02
Old Apr 19, 2003 | 08:04 AM
HtownDan's Avatar
HtownDan
MY FIRST 4x4
Go with 6. You will be much happier. I have a 4 and about to change to the 6 with 35's. Buddy has this setup and it drives a heck of alot better than mine. I have ProComp and plan to stay with it. Cepeks is good, don't like the superlift setup. Skyjacker has good results. Rancho is too stiff. Good luck. We'll all know the feeling you have right now.
Old Apr 19, 2003 | 09:45 AM
SouthPCraz's Avatar
SouthPCraz
MY FIRST 4x4
thanks for the reply guys i didnt know 35s would rub with a 4inch so ill probably be ordering a 6inch from skyjacker do you guys order their best kits or the ones with add a leafs or blocks i have heard add a leafs can mess up if your leaf springs are old and that blocks make for a ruff ride
Old Apr 19, 2003 | 11:32 AM
greystreak92's Avatar
greystreak92
MY FIRST 4x4
Personally, I'd avoid blocks like the plague. Too easy to have them squirt out from between the axle and spring in serious off-road conditions. Add-a-leaf helper springs are better but you are right, they tend to put greater stress on the spring eyes and if your springs are older, this stress can snap them at the eyes. If you can afford it or are willing to save the money to put new spring packs under it, you will be better off in the long run.
