240,000 miles plus on a 6.4L
Received 1,447 Likes
on
You sound pestimistic that your engine will not last for 200k miles! With your oil change program I would expect minimal 500k miles.
The exceptions are: burned valves, broken EGR cooler hydro lockin the engine, premature upper valve train wear, HPFP failure, DPF that don't last 150k miles, and cavitation issues.
Just kiddin of course...
hey guys ive an 08 350 6.4 xlt super cab 4x4 70,000 i just traded for 12 6.7 250 super cab am i doing right ive fought ford about regen white smoke and oil growing they pretty much washed there hands of the truck so i figured to just give it back to ford in trade also in mass we cant put pass plates on 350 over 10001 gvw anylonger so went to 250 10000 even foxtrk2
As to the growing oil, I trhink you have the same DPF clean technology on the 12 as you had in the 08. They still use the back injectors to pour fuel into the exhaust and some of it will still get in the oil. The stuff you have to buy and add to the truck is to help control NOX, not clean the DPF. At least that's how I understand it. Stand by and somebody who knows for sure will answer. Anyway, good luck with the 12 and come by and let us know how it works out for you.
on
Good luck....
I thought he said he couldn't do it any longer, maybe a change in the law. I can tell you for sure it's that way in NY. I came across a bridge from NJ to NY a couple years ago. Bridge looked like it was from the 1920s. I mean the lanes were skinny and I'm driving a DRW truck and pulling a 5er 8.5 ft wide and I'm thinking they should consider condemming the bridge. I get to the NY side and there is a toll gate. I think it was $23.50 or maybe $32.50, anyway I say what up with this and she says commerical vehicle with 4 axles. It's automatic in NY and you can't drive on their parkways either. bummer.
your right about it being new in mass well newly enforced as of this year anything over 10001 has to have comm plates and dot inspection as on 2012 even my insurance adjuster arned me about it so before they refuse my new plates im down sizeing and i dont need the 350 gvw for what im towing anyways so maybe its all for the better the 6.4 i think is going to turn into a horror story in time an dim not wanting another in my life im retired and choose to go the easier route thanks guys foxtrk2
If I recall correctly, are you draining your oil partially and replacing with new oil between oil changes? If so, how's that working? OA's?
RM, he posted that just the other day as a matter of fact.
https://www.ford-trucks.com/forums/1...l#post11261647
I did it for 2 cycles, 10,000 miles. I had one OA done after the first 5000 miles and it was very good. Every thing in bounds. By the end of the second cyclle I had decided to delete and just happened to find a used tuner at the right time and went ahead and did it. I'm convinced that the oil program was very helpful to the engine and had I not deleted I'd still be doing it. The program was every 1000 miles drain down to 1 quart low and replace that quart with new. Had it down to about 15 mins.
