5.0L Coyote 5.0l Ford OHC Coyote engine for 2011+
Does the truck Coyote have a front or rear sump oil pan?
Old 04-22-2012, 06:09 PM
jade79's Avatar
jade79
jade79 is offline
Just wondering, I'm planning a swap in an older truck in the future and trying to work out all the logistics before I go buying or cutting anything. Thanks.
Old 04-30-2012, 11:27 PM
Gary Atsma's Avatar
Gary Atsma
Gary Atsma is offline
Here's a tip for ya; go to a dealer and find an F-150 w/ the 5.0L. Then get on your knees, bend down, and LOOK under the front of the truck in question. You will then answer your own question. See how easy that was?
Old 05-01-2012, 07:15 PM
jade79's Avatar
jade79
jade79 is offline
Gary, If you're having a bad day or troubles at home there's no reason to take it out on me. I merely asked a simple question which should not provoke a smartass answer like that. If you're going to respond to threads like that again maybe you should do us a favor and stay off here.
Old 05-01-2012, 09:53 PM
Gary Atsma's Avatar
Gary Atsma
Sorry if it came off that way. It's just that you are more likely to see the truck in question on the street or car lot before you would get the answer you are looking for here. Notice that a whole week elapsed between your post and mine. And my post was your first response, hence the bit of sarcasm. Something like sump position is something most folks don't concern themselves about unless they're thinking of using the mill in an engine swap, which is why you oughtta just look under a new truck and find out for yourself firsthand. A personal view or picture are worth a gazillion words, plus you would see other locational relationships of components you might be needing to know. I was really trying to help you, but got a little sarcasm in the way. Sorry.
Old 05-02-2012, 06:30 PM
jade79's Avatar
jade79
jade79 is offline
No problem Gary. Out of the few current model F series trucks I've had the opportunity to check out, they either had the 5.4 or Ecoboost V6. I was just figuring someone that changes their own oil would recall and chime in. Thanks.
Old 05-02-2012, 08:21 PM
Gary Atsma's Avatar
Gary Atsma
Actually, I think that the sump position would be the same no matter which engine, in order to clear the front suspension crossmember. Very old trucks (Fords of course!) had front-sump pans because more of the engine was in front of the front axle. Nowdays, more of the engine is rearward of the front crossmember, probably needing a rear sump. But having not investigated this, I really don't know. But in line with this reasoning, I would think that wherever the sump was on that 5.4, is also where it would be on the 5.0. Just an assumption, but an educated one. Still, visit the dealer, see a new one, and know for sure. Good luck!
Old 06-11-2012, 04:33 PM
Boss5.0's Avatar
Boss5.0
Boss5.0 is offline
There is only one answer and that's in the rear.
Old 06-11-2012, 08:15 PM
Gary Atsma's Avatar
Gary Atsma
And there you have it....... (he musta looked at one.......cuz he has one.....END of debate!)
Hey Boss, just saw what ya got. How do you like it so far? Were all the mods worth it? As in, would you do anything different?
Old 06-12-2012, 04:24 AM
Boss5.0's Avatar
Boss5.0
Boss5.0 is offline
Go get one and see for your self.lol
Old 06-14-2012, 07:38 AM
craftsmangary's Avatar
craftsmangary
craftsmangary is offline
I'm thinking about doing the same thing in a old Ford pickup. Have you figured anything out yet?
Old 06-16-2012, 04:57 PM
dave91gt's Avatar
dave91gt
dave91gt is offline
It is a rear sump.
Geez guys. If you can't help him out why post an answer?
Old 06-16-2012, 10:25 PM
Boss5.0's Avatar
Boss5.0
Boss5.0 is offline
Originally Posted by dave91gt
It is a rear sump.
I thought I did.
Old 06-16-2012, 11:47 PM
Gary Atsma's Avatar
Gary Atsma
You DID! (see below)(tried, but forgot how to delete this post..)
Old 06-16-2012, 11:52 PM
Gary Atsma's Avatar
Gary Atsma
Looks to me like you did; some folks just aren't that observant......
Old 06-17-2012, 09:30 AM
dave91gt's Avatar
dave91gt
dave91gt is offline
You did Boss. My bad!
My apologies. Just wanting to help out.
Olin1008
04-09-2023 02:41 PM
robertrpeak
10-06-2016 08:39 AM
F-adams
03-19-2016 07:20 PM
DALEDIESEL
11-17-2014 11:48 PM
joe blow
03-13-2009 12:31 AM
Quick Reply: Does the truck Coyote have a front or rear sump oil pan?
