1964 C600 decode
Welcome to FTE!
I'll give you your own thread for this truck. If you have additional questions and post on this thread, it will be easier for others to see what we're talking about.
C61 = C600 gas
D = 292 4V Ford Y-block gas V8. Might be the HD version.
U = Louisville Assembly Plant
461692 = 1964 numerical series, October 1963 production. (C series numbers are said to start at 465--- for '64 and '63 is said to end at 445000)
153 = 153 inch wheelbase
No color code. This truck is not a special order, so possibly a typo on the plate. Looks yellow to me on the door. Possibly a white repaint on the rest.
C610 = C600 gas, 21,000 lbs GVWR
91A = I do not have upholstery info for this model year
F = Borg Warner model T98A four speed transmission
F2 = Eaton Model 15201 2 Speed Rear Axle / 5.83/8.17-1 / 15,000 lb. Rear Axle Capacity
No front axle code unless an optional axle. Your axle should have at least a 6,000 lb rating and no power steering.
21000 = 21,000 lbs GVWR
153 3600 = 153 certified net HP @ 3600 RPM
72 = San Jose District Sales Office.
C61 = C600 gas
The following users liked this post:
Engine codes:
A: '64-'65 330 2V MD
C: '64 292 2V, '66 on 330 2V MD
D: '64 292 4V, '66 0n 330 2V HD
M: '64-'65 330 2V HD
As to the 330, put another way courtesy of @NumberDummy :
The 4th digit of the VIN is the engine code.
A = 1964/65 330 MEDIUM DUTY
C = 1966/72 330 MEDIUM DUTY
M = 1964/65 330 HEAVY DUTY
D = 1966/72 330 HEAVY DUTY
So...both the 292 and the other FT engines were available in '64. How yours is coded for a 292 but has a 330 is a mystery.
Most likely is a replacement engine some time in the last 59 years.
Your engine shows blue paint--Ford started using blue on all engines in '66. I can't tell what carb it has. The air cleaner says HD, which should be a Holley 2300 series. An MD would be an Autolite 2100.
If you can find a casting number or two, or the date code, we can see when the engine was produced.
Check your transmission case for casting numbers etc. Your engine might have come over with a different transmission too.
