Oil cooler and bullet proof EGR cooler failure in 2k miles!?!
this is how I do it to
and by the time I get the turbo and uppipes lined up the turbo is pretty cockeed away from the pedistatall. so the turbo mount bolts to the pedistall are kinda a fight but the ypipe to turbo joint is tight as a Bulls ****
Just smear antiseize in the V-Bands on the marmon clamps just gives it alittle slip and draws things in tight
I wont be able to get to his truck until during the week...Ill text you soon Greg, as soon as I find my phone.
that kind of scares me that you have all this experience with the turbo on/off, and it still kicks your behind.
best of luck
edit: didn't mean the part above to seem questionable about your skills...instead, WTH is the turbo so dang hard to install?
my 06 has green in it right now. was that way from factory as best we can tell. Truck only has 1 repair report on OASIS for something stupid that they didn't even pop the hood for.
and with it having 9,800 miles when I bought her...I can't see anyone changing coolant. truck only got 3,500 miles from Jan 2006 to June 2010. I might be wrong, but it's just one of those things that people never look at really with such low miles
best of luck
best of luck
best of luck
As far as the coolant, I always ran the green stuff in it, my EGR cooler and OIL cooler failed 2 weeks after buying it. Ever since then, its still been the green coolant and my temps were never a problem after the first failure which the truck had 199K at the time.
Okay guys...here we go again....
Good news/bad news!
Took me about 15 minutes to get the up pipe lined up to the turbo...no more leaks there Started the truck, found a leak around the EGR cooler where it meets the up pipe, fixed that....Now, we still hear a leak...but the truck builds 25lbs of boost all day long....Is it possible the up-pipe is cracked/broken from all the pushing and prying of it?
Well this is the most part....We took the truck around for a quick spin, went good, rough running but as expected with all the work we did.
We changed the oil, fuel filters, and flushed the coolant system.
Put it all back together heading home, got to a stop sign, truck started idling BAD, BAD injector knock....to the floor it would only idle, wouldnt go up or anything..the truck would run at like 300RPM before it just totally dies out...
I tryed unplugging the ICP, and no change, check all plugs/connections all good.
Is there anything I should look at/for? I would think the IPR, but if it were that...the truck just wouldn't run correct?
PS, the truck still rough idled throughout the whole time driving it, I figured it still needed to clear out...we put about 8 miles on it all together, so I don't understand why it would go decent until we tryed to drive it home.
Im LEAST concerned about the uppipe leak, I am way more concerned about this truck not running anymore.
BTW. all FORD filters.
Good news/bad news!
#28
#29
When theres air in those HPO rails it will cough and sputter for a few minutes but the Longer it Runs the Smoother it should get But since it got worse the longer you ran it Im almost Betting the IPR got Jacked Up it just took a few to collect junk on it screen
and it could have cracked a flex joint on the exhaust might try and hang a string on a stick and hang it around the uppipes and see if it blows around
