zf swap, tcase no 4 low
ok so i have a 93 that i swapped in a manual tranny on in place of the e4od, i did not swap in a computer from a manual because i couldn't find one. i have an electric tcase and while it does shift into 4hi it wont go to 4 low. i'm assuming i have to ground out the what used to be the neutral safety switch somehow. can you anyone help? seeing as my wire diagram from chiltons sucks, pics would be the most beneficial. thanks.
Checkout this link, your answer is on page 2.
Kenny
Adventure Offroad • View topic - ZF Swap with Pics
Kenny
thank you for the link but he used a manual tcase and what he showed was how to get the truck to start. i've done that already. been driving it for 3 months now. those are the same wires i've got wired together now. lol. i'm trying to get the electric tcase to go into low range. i know it's got something to do with the neutral safety switch on sensor that was on the e4od. i've still got the harness so if i figure out which two wires to jump together then i can make it work. just need to know which two.
ok so i got it figured out....here's my thread over on FSB for anyone else wanting to do the same...
zf 5 speed conversion - FSB Forums
hav24wheel
10-25-2010 12:54 PM
BadBlk95GT
1978 - 1996 Big Bronco
09-02-2004 09:49 AM
