radiator leak on 2008 f250diesel
had to shell out 1280 on a radiator replacement for f250 2008 diesel truck. radiator was cracked. heard it was a common problem and ford would not give me a break. original bill wqas 1400 but dealer gave 10% off. still believe ford should pay for part .cost of radiator was $900. told not under warranty. any idea how to go forward to get ford to pony up for some of the cost. truck radiator flushed inOct and noticed small drip. thought it was an overfill. millage was 80000when took it to dealer tuesday.
Only hope would be if the hoses were leaking before hand and they can't leak in the middle, then it doesn't count either way. Did they upgrade to the 2 O ring hoses at the same time? That is a $600 fix in and of itself. More than half that is labor so they could have done it pretty cheap since they had it apart.
Hey Guys,
Don't post much but wanted to chime in on this . back in March '11 ,my 08 6.4 sprung a leak from the radiator . I then had 15k miles and was 1 month out of warranty ! I tried to get some support from ford and they told me to pay $500 and the rest of the job is covered..
honestly not to bad ,not to be greedy but I never had a warranty concern in all of the 1st 3 years of ownership . just thought at least on a one time basis just take care of the whole thing.especially the fact it is a very known issue.
But to end the story,when I wen to the dealer to pick up the truck .the service manager and I went to check the vehicle before paying the bill.we opened the hood and found trans fluid all over the frame rail and dripping on the ground.It wasn't leaking ,it was just left a mess after the job .. He offered to get it cleaned up, I told him to forget about it .at that moment, he said to forget the $500 and the dealership took care of it..
I hope I didn't bore anyone with this long story
happy new year all!
Ray
happy new year all!
Ray
The net cost of the radiator is around $550 as marked on my repair recept when my radiator failed and was covered under warranty. I don't want to scare you, but there have been owners who have posted here 3 and 4 radiators replacements on their truck. I reported mine to the NHTSA.
I have 1600 hours on mine. I think it has lasted due to long runs, less thermo shock.
My buddy's was replaced on his 2008 with 65,000 miles without a hitch under warranty.
Thought they were extended to 100,000?
https://www.ford-trucks.com/forums/s...d.php?t=928569
I was just looking at his last night
11-1-7*** 6.4L DIESEL ENGINES - RADIATOR LEAK DUE TO HYPER-EXTENDED BYPASS THERMOSTAT
It's covered for 5/100K if it broke due to the thermostat
