7.3 wont start after injector replacement
not sure what fuse that is. ill check. i do get the wait to start light. i drained the filter housing and ;cycled the key a few times but no fuel is pumping into the the housing. i filled it with diesel and still wont do anyting. there is a buzzing from something on the firewall passenger side. what is that?
on
ok so i found that my fuse for the fuel pump is blown i replaced it and it blew again. is this the one you are talking about?
ironic that you and I are running into the same issue after an injector install, however I do not have a blown fuse. Might want to check into whether or not your injectors are even firing. I know mine are not. If you have an AE run a buzz test. Mine failed the Buzz test so I know there is a communication issue between the IDM and the PCM because if threw a code after the buzz test
Jerry said his truck fired right away, then died and hasn't been able to restart. His problem is no fuel since the pump wouldn't fill the filer housing. He's got either a short in a wire, or the pump is bad.
Now if the fuel gets fixed and the truck still doesn't fire up, then a buzz test would be a good step.
