Top overhead display
I have a 2001 F250 Lariat- the top center console (not sure what it's called) stopped working- It has a display that shows temperatue and fuel status etc- I'm not sure what it's called- i checked fuses and don't see anything blown but in the manual I'm not sure what they refer to that component as- Any thoughts? If not a fuse- what can it be?
I am thinking you have the common circuit board problems with your unit. Some people are handy and fix them themselves. There are some resistors that become loose and fall out of the circuit board, and they solder them back in. Do a google search on it and you should be able to find some websites that explain the procedure if you want to try it.
Robert6401
10-07-2010 02:52 PM
